what chainring to r...
[Closed] what chainring to replace fsa?
can anyone recommend a decent middle chainring? the standard one for my fsa is out of stock everywhere otherwise I would have just stick with that.
anyone rate these?
http://www.chainreactioncycles.com/Models.aspx?ModelID=3331
also, I'm assuming most rings/crankarms are a standard size between the bolt holes, can anyone confirm?
Thanks
Posted : 31/01/2010 6:29 pm
When I can afford them thats what I go for. If on a budget go for the hardcoat over the slick-shift - FWIW I've had both slick and none-slick and couldn't really tell any difference in shifting. They don't last forever but I've had far less chain-suck issues (only time was the mud-fest of SITS 08) than with any other make.
AFAIK unless you have XTR you just specify whether its 4 or 5 bolt - thats all I've ever had to do with LX HT1 / 2, XT HT2 and RF Evolve.
Posted : 31/01/2010 6:34 pm
Mmmm....never really that worried by the chain rings - I usually go for something quite standard and hard wearing (Shimano XT) - and they are cheaper than the Middleburn!).....also would look at the SLX which comes in at £25 or the LX at about £21.
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=5702 ]Shimano[/url]
As for size "most" are 104BCD if you have 4 bolt - what cranks have you got and I could probably tell you? I know they are FSA, but what model?
Posted : 31/01/2010 6:38 pm
thanks guys, its a k-force crank, these are the rings that come on it:
http://www.chainreactioncycles.com/Models.aspx?ModelID=4007
just noticed that says 104mm on the description so I guess it should be standard?
Posted : 31/01/2010 6:47 pm
Yeah fine then buddy... 104mm BCD is pretty standard - so any of the 32t 104mm BCD rings will fit. I forgot to say that the Shimano's shift pretty smooth as well IMO.
Posted : 31/01/2010 6:50 pm
cool, thanks again
Posted : 31/01/2010 6:57 pm
