What budget HT fram...
[Closed] What budget HT frame for Mulleting?
 Earl
29 front 2.5/2.6 tyre - 120-130mm fork
27.5 rear 2.8/3.0 tyre
165mm crankarms
What do you base it on?
29er frame? Resulting in a lower bb, but with long chainstays?
27.5 frame? Resulting in a high bb, but with short chainstays?
My short list so far.
Sonder Transmitter 27.5 (£300)
Dartmoor Primal 27.5 /Hornet 27.5/29 (£280)
OnOne Scandal 29 (£300)
Thoughts please?
Posted : 25/08/2020 4:17 pm
I've got an unused XL Scandal frame with your name on it for £280, complete with headset, spare dropout and extra QR axle.
Posted : 25/08/2020 6:13 pm
The orange clockwork frame in my loft that needs shifting?
Designed around 130mm 29er fork will take a 27.5 x 2.8/3.0 up the back end
Posted : 25/08/2020 6:33 pm
The Transmitter is a bit narrow at the back. You will struggle to get a 2.8 in with any mud clearance.
I’d spend a bit more on the frame for something like a Chameleon or a Pace. The RC 627 will fit a 2.8 with the dropouts moved back a bit and you’ll also be able to fit a 29er with a 2.4 for less hardcore days. Or you could go for the RC 529 to get an even lower BB height.
Posted : 25/08/2020 8:06 pm
I mulleted a Moxie, but it lacked grip on the front. Much improved with straight 29er. I think the problem is insufficient weight on the forks.
Posted : 25/08/2020 9:45 pm
 Earl
Could it be it made the moxie too slack?
I've mulleted my son's wee bike and it took the hta down to 65/66 on my phone app.
I found.it willing to corner alot more
Posted : 25/08/2020 10:43 pm
 Del
i wouldn't have said your proposed configuration that radical in mullet terms even though there is a reasonable difference in OD between a 29er and a 27.5+. you'll want a 29er/27.5+ frame anyway. i'd be surprised if there are many 29er or 'straight' 27.5 frames around that will take a 2.8 comfortably.
Posted : 25/08/2020 11:30 pm
 Del
FWIW I have a chameleon i'm likely going to try with a similar setup at some point just because i already have 29er and 27.5+ wheels/tyres.
Posted : 25/08/2020 11:35 pm
