What bars & ste...
[Closed] What bars & stem for a 29er?
6 Users
I am looking for a set of bars and stem to go on my rigid 29er,anyone got any suggestions or using something they would recommend.
Posted : 22/10/2009 7:41 am
What you got on your other bikes?
Use them.
Posted : 22/10/2009 7:42 am
some of those lady bars on joneses or on ones. 😉
Posted : 22/10/2009 7:44 am
High rise
Medium rise
Low rise
Flat
Mary
Fleagle
h
carbon
alluminium
Easton
USE
FSA
Titec
And a million others will all steer it quite well.
And dont even get me started on Grips.
Posted : 22/10/2009 7:50 am
If you're on a 29er to try and be 'different' then make sure you get some funny set up or you'll be shunned by the proper niche-wh0res - maybe some roadie drop bars or pretty much anything other than a riser or flat bar.
Otherwise, just use what you have on your other mtbs but maybe with a lower rise for the bar or flatter angle for the stem to make up for the typically higher front end on a 29er.
Posted : 22/10/2009 7:51 am
agreed.
Im currently using mid rise monkey bars, which even with a 5degree flipped stem is a bit high with the big forks (OK with rigids) so I may hunt down some flat bars soon.
Posted : 22/10/2009 7:54 am
