protector for a rear derailleur ?
Yup derailleur protector.
Chaps above are right.
Ahhhh ok. I've actually set-up my bike fully, gears set-up etc. Would you recommend starting again to fit this or is it not really a necessity? My derailleur is pretty beat up already ๐
Thanks
TomO
I've never fitted one but I doubt it's hard to do - think they just bolt on, with the "spike" fitting into the mounting bolt hole in the top of the mech
I know but I'll have to re-do all the gearing again as it'll push the derailleur outwards. Just wondered if they weren't really that amazing if missing it would matter ๐
I can't imagine it pushing the mech outwards - I've always imagined that they just clag on to the outside of the mech
(as I say, never fitted one)
By the looks of it now I Can google what it is, the main derailleur bolts to it. So for me to fit it I'd have to remover the derailleur and it's fully tensioned.
No derailleur doesn't need to be removed. Shiny silver bit sits in the derailleur bolt hole and your through axle will pass through hole at other end.
I think it looks like the equivalent part to the outer black bit with the 5mm allen head showing in this photo. The big hole should go over your axle end and the smaller part is possibly a spacer or replaces the nut. If it came with your bike it must be in the manual. You should be able to fit it without any disruption to your indexing.
Pretty sure you want it in there so you dont have to screw the axle virtually past all the threads as it acts as a spacer.
No there's a lip on the axle that bottoms out.
Brilliant little device those.
Oh wow thank you! Didn't reqlise it acted in that way. Still don't really understand its point but you all make it sound good so ill fit it tomorrow morning ๐
Thanks for all the help.
TomO
Specialized UK recommend you don't fit the wee bar that slots into the mech.
