what an utter IDIOT...
[Closed] what an utter IDIOT i am for BELIEVING something EVANS told me!
 bonj
so i need a new mech for my MTB, i go into evans to get one.
I was about to buy a nice shimano shadow one, when the bloke says 'sram ones are very good, work well and have good clearance'
'ah but they aren't compatible with shimano shifters are they?'
'er.. yes, they are' he said.
'are you sure?'
'yep.'
'Can you check, 'cos i thought shimano had 2:1 actuation ratio and sram had 1:1 ratio or something like that, and therefore they weren't compatible?'
(goes off to check with 'the mechanic')
(comes back)
'yep, they definitely are compatible'.
ok then i'll buy it, cos i've broke two shimano ones recently.
get home, the inevitable discovery occurs.
WHY oh WHY do these IMBECILES feel the need to avoid saying "I don't know" at all costs!?! for ****s sake...
You don't know SH1T about bikes and you never fu*king will...
Still, i suppose like i say it's my fault for letting the moronic brainless little tw4t convince me against my belief of the truth.
ABSOLUTE CRETIN
Can anybody please tell me nice stories to calm me down and give me loads of good reasons why evans staff are worthwhile organisms because on tuesday when i take it back i'd rather calmly walk out with a shimano one instead of the police being called to chuck me out.
Posted : 21/06/2009 6:48 pm
Certain SRAM rear mechs are compatible with Shimano, they always have names and are usually at the lower end of the range, SRAM Rocket springs to mind.
Posted : 21/06/2009 6:55 pm
 Nick
Well yes, but don't let that stand in the way of a good rant especially when it's aimed at soft target like Evans or Dave Hinde etc
Posted : 21/06/2009 6:58 pm
Are you sure you haven't just put it on the wrong way round or something like that?
I didn't know they made derailleurs that work with shimano - though I know Rocket SHIFTERS do operate shimano mechs
Are you sure PePPeRrRrRRR ??
Posted : 21/06/2009 7:02 pm
NO sram rear mechs work with shimano shifters.
Posted : 21/06/2009 7:14 pm
There are sram shifters that work with Shimano mechs - called SX rather than X.
Posted : 21/06/2009 7:17 pm
They are halfwits, and dangerous too. Some especially low IQ mechanic there was convinced my pivot bolt was upposed to be in two halves.
Spare me
Posted : 21/06/2009 7:28 pm
I can't believe no one has posted the Ha Ha picture of Nelson from the simpsons yet. Come on guys, what gives?
Posted : 21/06/2009 7:46 pm
which store was it?
Posted : 21/06/2009 7:48 pm
Ah well.
Posted : 21/06/2009 7:49 pm
ooh look. an Evans advert next to this triumphal discourse.
Posted : 21/06/2009 7:55 pm
Hang on, your having a rant beacuse you f*cked up??
ABSOLUTE CRETIN
Nail on head..
Posted : 21/06/2009 7:58 pm
Posted : 21/06/2009 8:00 pm
and yes, the rocket and attack shifters run with simano mechs.
Its my prefered setup, becasue i can run a rapid rise mech, and the sram paddles are unmissably huge!
Posted : 21/06/2009 8:01 pm
Why wouldn't it work?
Its a rear mech, its not indexed. the mech allows the chain to move between two stops that are set by the limit screws.
The shifters move the chain and control how far it moves which has to match the cassette spacing.
So will a sram X9 mech work with a XT shifter, well it should.
Will it give you the best shifting in the world, well may be not.
Posted : 21/06/2009 8:22 pm
as I understand it the Shimano shifter would need 2 clicks per gear change, and leave the mech only half way across the cassette 🙁
Posted : 21/06/2009 8:41 pm
which store?
waits for captain toiletflush to comment..........
Posted : 21/06/2009 8:55 pm
The mech needs a different amount of cable pull per shift.
Posted : 21/06/2009 9:05 pm
My particular bout of 'special needs' mechanic encounter was Waterloo
Posted : 21/06/2009 9:24 pm
 aP
I remember years ago attempting to buy an expensive seatpost in Evans opposite Waterloo station and when I asked to buy it (£90 or so) the guy behind the counter reached up picked out a £5 seatpost and told me I should buy that instead. So I bought one from Condors instead which 10 years later I still have and use.
I never, ever buy anything from Evans that I need advice on as I know that it'll be wrong.
Posted : 21/06/2009 9:39 pm
He was probably right, £90 for a seatpost! My adjustable one cost about that. 😛
Posted : 21/06/2009 9:45 pm
I'm quite astounded that you knew it wouldn't work, yet let the grease monkey convince you it would. Who's the numpty?
Posted : 21/06/2009 9:48 pm
 bonj
brakes
what store was it?
nottingham
Posted : 21/06/2009 10:10 pm
 bonj
Exactly! that's why i'm angry with myself for being so stupid...
my only explanation is that i thought maybe just maybe he knows that they've recently changed them to be the same ratio.
Posted : 21/06/2009 10:11 pm
TheArtistFormerlyKnownAsSTR - Member
good point well made
Posted : 21/06/2009 10:12 pm
 bonj
yes, the sram mech only moves half way across the cassette.
basically SRAM shifters pull more cable than shimano ones.
Posted : 21/06/2009 10:13 pm
Evans (Waterloo Cut branch, fact fans) once told me "you can just undo the bolts a bit more" when one of their monkeys presented me with an Easton stem although I wanted a stem for my Cannondale Lefty and told them the Easton would be no good.
Avoid.
Posted : 21/06/2009 10:18 pm
