Welding Pannier Eye...
[Closed] Welding Pannier Eyelets... Is It Realistic
I don't know anything about welding, so this may be a dumb question...
One of the eyelets that my panniers were screwed into snapped off the frame on my way home today. If it's a simple job, it may be easier to get the eyelet welded back on than to faff around stripping my frame down and trying to get it replaced/warrantied. It also seems crazy to waste the remains of a good frame over a small thing, but I need to carry stuff in panniers.
Any thoughts on what I should do with it (and where would be able to do a decent job)?
Searching through old threads, a car garage might be able to sort it so I could try that on Monday.
Posted : 29/08/2009 8:30 pm
Steel or alloy frame? Much simpler with a steel frame to repair it. I would have the repair done by someone who specialises in bicycle frames - rather more delicate than the usual stuff welders do
Posted : 29/08/2009 8:34 pm
no it is a bank holiday ๐Ÿ˜‰
Assuming steel frame should be easy enough to do this.
Possibly use a seat post mounted version?
Posted : 29/08/2009 8:35 pm
The problem with a simple weld is the heat involved will burn the paint and if the frame is anything other than steel ,involves more proffesional approach than a garage may be able to offer.
Look up your local frame builder would be my suggestion ,at least for knowledgeable advice.
Posted : 29/08/2009 8:36 pm
Uh huh. Thanks for your thoughts, guys. Like you, I was thinking it might be quite a delicate job so I'll investigate what frame builders are around (W London).
The frame is steel so hopefully it should be possible!
No chance of a seatpost rack, BTW. I do carry some heavy-ish loads sometimes (shopping is the heaviest, especially when it involves beer).
Posted : 30/08/2009 7:17 pm
liquid metal/chemical metal [url= http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_223979_langId_-1_categoryId_165691 ]halfrauds[/url]??
where in london are you?? i know of a frame builder in croydon (roberts cycles)
Posted : 30/08/2009 7:24 pm
It would normally be brazed on not welded on.
Posted : 30/08/2009 7:25 pm
 Smee
What about a p-clip?
Posted : 30/08/2009 7:38 pm
I'm not keen on DIY for this one. I don't think I'd be able to get it strong enough and properly aligned. Roberts are worth a call, though. I never knew where they were based and it's not too long a ride over there from Hampton.
Definitely no to p-clips, it's the eyelet down at the dropout ๐Ÿ™
Posted : 31/08/2009 8:36 am
Is it like a rivnut? That might not have been welded into the frame.
Otherwise I'd get it warrantied if you can - whole lot of hassle & expense to get a repair that may not be up to it, void your warranty, knacker the paint...
Posted : 31/08/2009 8:41 am
[url= http://www.robertscycles.com/ ]http://www.robertscycles.com/[/url]
hope that helps.
i have had work done there from dent removal to total resprays and have always been top notch!! and resonably priced
Posted : 31/08/2009 8:43 am
They are brazed on. Try welding to a dropout and it'll crack along the weld *sometime* later. I tried this when a dropout cracked on one of my steel bikes.
I can't understand why you can't use a p clip on each seat stay just above the dropouts?
Posted : 31/08/2009 12:41 pm
As others have said: try a P-clip
My commuter ran a P-clip for years with no problems.
Posted : 31/08/2009 1:07 pm
