Water sloshing arou...
[Closed] Water sloshing around inside Orange 5 downtube... how to get it out?
Firstly: no I didn't jet-wash it!
I have absolutely no idea how it got in there, but, at probably a good 200 mls or so, I have a feeling it must be slowing me down a tad! ๐Ÿ˜ฏ
Is it best to try draining by dismantling the headset-forks end, or the BB?
Cheers! ๐Ÿ™‚
Posted : 07/07/2011 1:04 pm
take your seatpost out?
Posted : 07/07/2011 1:10 pm
Drill?
Bottle cages or bb, take out and drain.
drill some holes in the downtube? ๐Ÿ˜‰
probably best to have a go at dismantling both ends...
then air can get in one end while the water comes out of the other
though im guessing there might be a blockage somewhere... have a gentle poke about in the drainage holes at the ends of the tube with a spoke / other pokey thing if nothing drains out
edit: or use the bottle cage holes...
Posted : 07/07/2011 1:12 pm
seatpost out - bike upside down?
i forgot to put my grommet back on when i did the rear brake hose recently - im sure my old one is in the swingarm somewhere ๐Ÿ™ and of course is a great entry point for water ๐Ÿ™
 hora
Shoot it?
Posted : 07/07/2011 1:14 pm
It'll be the urine they extracted when they came up with the price. ๐Ÿ™‚
Posted : 07/07/2011 1:20 pm
I had the same problem there is a hole in the tube but mine got full shite and block hence the water retention . check for yours near the bb and poke the cack out
Posted : 07/07/2011 1:49 pm
 hora
Rusty lol!
Posted : 07/07/2011 1:54 pm
Forks deffo. Back of the head tube has big hole that opens through into ends of top and down tubes, so you can tip it out there no problem.
Posted : 07/07/2011 2:20 pm
Put the whole bike in the oven and evaporate it out!
Or if you dont have a big enough oven use a blow torch, it shouldn't take too long if you get it good and hot!
Or maybe saw it in half, drain it, then weld it back together again!
Posted : 07/07/2011 2:22 pm
Stuff a sponge in there to soak it up?
Posted : 07/07/2011 2:30 pm
A thirsty ferret?
Posted : 07/07/2011 2:32 pm
Thanks for the advice!
๐Ÿ™‚
Posted : 07/07/2011 3:43 pm
That sort of approach could only lead to improved aesthetics when we're talking Orange.
Posted : 07/07/2011 4:49 pm
 j_me
Don't ride it unless it's subzero
Posted : 07/07/2011 4:59 pm
but he said its a 5
Posted : 07/07/2011 5:22 pm
You could always fit this... ๐Ÿ˜‰
Posted : 07/07/2011 5:25 pm
@ to tall and lipseal : lol
Posted : 07/07/2011 5:32 pm
