New shoes, use a rpm indoors to connect to iPad. Any tips for how to fit it? It looks like I might be stuck using the old pair with straps?
Any ideas?
Yes that's the one you can fit it to your shoe by threading the strap through the back of it to give cadence readings.
Just fit it to the crank arm
The shoes are used across multiple bikes hence why I fit to the shoe
Isn't end of the world thought there might be a cleverer person than me whose come up with a solution
Put it in your sock and fold it over. Tip from dcrainmaker. Works with he Garmn ANT too.
Hmm interesting. I wonder if that would work with the Garmin speed sensor that's meant to attach to wrap around the hub? Assumed that the orientation was somehow important but I'd like to be able to attach it side on to the wheel.
Velcro, sho'ly ?
