Btw- I’ve not seen 2 versions of the chart, just the one on TF tuned site.
There’s a new one?
Ok- so just looked at Vorsprung site chart, which has revised the weights down by 5lbs for my category, I still think the ‘soft’ setup option is more like the how the medium should be, but it’s closer now.
Are the springs swapped out or is each different rate purchased outright?
Just the spring, which is about 60 quid. Pretty easy to undertake yourself as well.
hi this is kind of why i asked about the bottom out setting. i feel i'm not getting max travel but the sag is right. it's fantastic off the top, roots etc took it to the bike park on saturday but it was only the tamer trail open due to snow. wondering if my spring is correct
Due to the spring rate chart being ‘out’ by quite a bit, TF Tuned have changed my spring (1 of them so far) for free.
Good service from them as usual.
ok may contact them
am currently in contact with Vorsprung and yes turns out my 55lbs is wrong and it should be 50lbs.
Hope i dont have to fork out for a new one.
anyone have a 50lbs spring they want to sell or swap for a 55lbs?
I have a 55lb spring in my 2019 Yari 170mm, am 95kg kitted up with rucksack & water etc, went for that spring as on an e-sommet get about 20% sag early days in testing but seems good
Yes i'm 80kgs fully kitted up, 150mm fox and their new table says 50lbs. I'm pretty peeved and this is gonna cost me another 70 quid to get it working as it should . Vorsprung said there is a theoretically a 9% difference in spring rate between springs.
I didn't fit it myself. it's an easy job to to just pop out the old spring and put in the new one?
HI all, I didn’t fit my smashPot myself, now it’s time for a lower leg service on my 36. Anything to think about / do different?
Same procedure just more oil in the spring side.
Cheers ok
thread resurrection here! two things:
i need to change from 15mm travel to 170mm, its an easy job right.. take it apart and move some stack spacers?
Also, my bottom out adjuster seems to now only move approx one full turn, no clicks, and it doesn't do anything. any ideas?
Easy enough to change the travel but you'll need some heatshrink to replace the stuff you'll have to cut of.You need to change the number of small inner spacers and the large outer ones to change travel.
Not sure about the bottom out. Is the adjuster shaft bent?
Take it apart and have a look. Again easy to do, just take note of how the shims are stacked.
cheers, good point about the heatshrink.. will need to source some of that
How often are people doing a lower leg service on their forks with the smashpot fitted?
Holy thread resurrection, batman! I've never done one of these before, kinda proud to do so 🙂
Really thinking hard about this for my Pike on the hardtail. My favouritest fork ever was a coil lyric BITD on a bike that got nicked. Want to recreate that feel, and as I am a heavy bugger I reckon this is a good call.
@lardman if you got the 50lbs spring, 10lbs lower than recommended, how did that feel?
I'm 120kg fully kitted, and it was reckomending the 75lbs spring. now, given the fork pressures I run have always been way lower than what RS recommends, and your comments, I'm thinking 65lbs would be more realistic.
thoughts appreciated!
Cant say much about the spring weight, but your Pike plus this kit (with its hydraulic bottom out) should be grand for you.
I was also thinking of resurrecting this thread with a different question - I rushed a spring change recently and my previously silent fork is now clunking. Suspicion is lack of preload (its not a topout clunk) as per the manual - anyone else gone through similar? Easy fix, but better to check before draining the oil and pulling it apart
Yes, had this when I swapped springs out once.
Yeah that’s the bit I’ve been looking at too. I’m now on 10mm so time for another washer. A tad annoying that the want you to put the spacer in at the bottom
No need to drain the oil to adjust the preload.
Just undo the topcap and compress the fork then adjust.
Mine came back from having an Andreani piston fitted and had a pretty bad clunk/rattle.
Tried altering the preload with no luck.
On closer inspection the heatshrink had wound it's way up the spring.
Re fitted some new stuff further down the spring and now it's silent again.
Edit.
Just seen your new post.
Unless you can get the big spacer out somehow you will have to drain the oil and take the assembly out.
@big_scot_nanny when I got mine I was told to go by body weight, not fully kitted weight, as the chart accounts for this. I went for the lower of the two options I was near and it’s been great. Shop offered a free spring swap after a couple of rides if needed. As far as the chart goes, Vorsprung are based in Whistler and their idea of hard riding may be very different to a UK rider’s.
It’s on my ebike which doesn’t see a big jumps so haven’t been using full travel, even with HBO fully open. Have just rebuilt them with a couple of the shins moved to lighten up the end stroke, but haven’t had a chance to text the difference yet. You can also run lighter oil to accomplish the same thing, although the shop has already recommended using 15wt instead of 20wt.
I was advised to go to a 55 spring by TF and Vorsprung, currently on a 45 spring, with 10wt oil
About 78kg to 80kg body weight here.
50lb Spring and 2 clicks of HBO from open using 20 weight oil.
50lb spring and a lot more clicks of HBO from open using 10 weight oil.
The forks have just been sold with the bike they were on and replaced with a an Ohlins air RFX 36 M.2.
The Ohlins is good but not as good as the Fox 36 Rhythm with the Smashpot.
Does anyone know the specs of the heatshrink? You can buy it from TF Tuned but even they agreed it’s the most expensive heatshrink in the world when you buy it that way
P.S. the stuff covering my spring has clearly been for a wander too, so the preload may be fine after all
I've used this
https://www.ebay.co.uk/itm/273312888267
If you're bored have a read of this https://www.mtbr.com/threads/vorsprung-smashpot-coil-conversion.1090922/
I emailed the Vorsprung guys and they gave me the speck for the heatshrink.
Was a while ago and I cant remember what it was now.
bruneep
Full MemberI’ve used this
Ordered thanks
I'm changing travel and I want to source heat shrink myself. What size do I need?
Spring:
2:1 singlewall polyolefin non-adhesive, with an initial (non-shrunk) diameter of 1.25" (32mm). 1.5" (38mm) initial diameter will also work.
Outer tube:
2:1 singlewall polyolefin non-adhesive, with an intital (non-shrunk) diameter of 3/4" (19.1mm)
Holy thread resurrection, batman (again).
Just going through setting up my smashpot in a 180mm Yari. Vorsprung table/guide recommended 45 or 50 lbs springs (I'm circa 95kg). Having spent the last 2 weekends at bike parks I've only used about 60% of travel. 417 last weekend used 100mm travel, on the 50lbs spring. Swapped for 45lbs during the week and BPW today has used maybe 120-130mm.
HBO wound fully off, LSC and MSC basically fully open, no HSC on the Yari UP damper.
Should I keep dropping spring weights until I hit a point where I'm at a deeper sag and occasionally using full travel? Or should I look at changing HBO oil to something lighter (can't remember what's in it currently). Is there anything else I should be looking at?
If anyone has a 40lbs spring they're willing to part with (for cash), PM me. Likewise if anyone wants a 50lbs spring PM me.
I'm 83kg and use a 45 lb and get full travel. How much oil do you have in Latest volume is 90ml the MTBR thread said to start at 50ml and add more as you feel you need. top of head I have 70ml of 68k oil not sure where the HBO is. Have you moved the HBO shims about?
Watching with interest as I'm finding my Fox 38 too progressive and was wondering if a Smashpot might be the answer.
Oh just checked order its a 40lb spring
