Using V brake lever...
[Closed] Using V brake levers for cantis. Same cable pull.?
As above, do they pull the same amount of cable.?
Posted : 05/08/2011 7:23 am
 aP
No
Posted : 05/08/2011 7:34 am
Will I die if I use v brake levers.?
Posted : 05/08/2011 7:37 am
You won't die, but your brakes will feel very hard and have less modulation than with a properly matched lever. A V lever pulls much more cable than a canti brake lever.
Posted : 05/08/2011 7:39 am
They'll just be a bit crap - hard and little power
I expect that with some bodging the V Brake lever will be OK for the canti but not the other way around? As long as you have and adjustable reach then I am sure you can get them to a usable position ๐Ÿ™‚
You can get inline bar levers for cyclocross which plug into the STI setup?
http://www.tredz.co.uk/.Cane-Creek-Cane%20Creek-Cane-Creek-Crosstop-Cyclocross-Brake-Levers_18966.htm
Had the misfortune to ride such a set up many years back(before V-brakes existed, Kona High Command levers were mis-specced during production and ended up with a similar pull ratio to V-brakes). Superb solid feel to the lever, virtually no stopping power whatsoever though, the only chance of locking a wheel was on slippery mud, just when you didn't want it to.
Posted : 05/08/2011 5:50 pm
