Using SRAM Rival wi...
[Closed] Using SRAM Rival with a 36t Cassette?
 FOG
Looking for a really low gear on my road bike I bought a 36 t cassette to replace the 32 as I had read on the SRAM site my derailleur would cope. However I had misread this and 36 only applies to the CX single ring Rival mech. I had adjusted the B screw until it worked ok but it now seems to have bent the B screw due to the angle of the mech making changes on the bigger cogs impossible.
Anyway I can make this work without buying the much more expensive CX mech which apparently works with single ring only anyway?
I looked at the Lindarets stuff but they say they work with Shimano only.
Posted : 04/08/2016 11:39 am
I don't understand, I have Rival HRD22 with a 36 cassette which is ran with a compact.
My mech works fine.
Posted : 04/08/2016 12:08 pm
 FOG
Mine did at first but now won't play!
Posted : 04/08/2016 12:19 pm
 mboy
Just buy a SRAM MTB Mech. Same pull ratio and allows you to run larger cassettes. I ran an X9 on a Apex 10spd setup in order to run an 11-36 in a 2x10 setup.
Posted : 04/08/2016 12:27 pm
I think Lindarets do an adapter which might allow you to use a bigger cassette - it might be Shimano only though
Posted : 04/08/2016 12:52 pm
http://www.lindarets.com/roadlink/
Rival in Medium cage goes to 32T, Long cage to 42T. I suspect FOG's is medium, Soccades's is large. PS. I have a medium which is 75mm centre-to-centre on the jockey wheels. So not tried bigger than 32T
Posted : 04/08/2016 1:44 pm
 FOG
Do you need an 11spd sram mtb mech for it to work or will 10 do?
And has anybody tried the Lindarets with sram mechs?
Posted : 04/08/2016 2:54 pm
New B screw or stronger ,longer alternative? Cheapest option,worth a try surely.
My Apex medium mech works fine with a 36tooth and compact.
Posted : 04/08/2016 3:06 pm
 FOG
Well, I have tried nick1962's suggestion and replaced the bent B screw with a stainless item of the same thread. All is back to nice smooth shifting though getting the bent screw out of the mech thread was a pain.
However I am still puzzled as to why the original B screw bent but I shall keep a very close eye on it in future.
Posted : 04/08/2016 4:47 pm
