Using Memory Map OS...
[Closed] Using Memory Map OS files in Oruxmaps ?
7 Users
Can someone tell me in simpleton terms how to use my Memory map OS files in oruxmaps and also how to import MMO routes?
Thanks.
Posted : 14/03/2015 5:36 pm
Have you tried mm navigator it's not on the play store but you can still find it on the web
Posted : 14/03/2015 6:17 pm
I've never found any other app that read MM maps - plus the recent ones are encrypted. But if you do manage to load them, GPS Babel is good for converting .mmo into any other route/track format.
Posted : 14/03/2015 7:50 pm
Any links to mm navigator?
Posted : 14/03/2015 8:01 pm
Possibly means mmtracker. Links here http://singletrackworld.com/forum/topic/psa-for-memory-map-and-android-users
Posted : 14/03/2015 8:27 pm
Yep that's the one
Posted : 14/03/2015 8:36 pm
Yes, MM Tracker works nicely. Not on the Play Store anymore, but you can probably find an APK file to download.
Could also try AlpineQuest, it can load Memory-Map OS maps (QCT files), plus maps from a variety of other sources. https://play.google.com/store/apps/details?id=psyberia.alpinequest.free
Posted : 15/03/2015 12:54 am
I couldn't get mm tracker to work on my old phone, might try again. Will take a look at alpine quest aswell. Thanks.
Posted : 15/03/2015 2:02 pm
for later versions of android you need the patched version from this thread -
[url= http://forum.xda-developers.com/showthread.php?t=816407&page=59 ]http://forum.xda-developers.com/showthread.php?t=816407&page=59[/url]
work backwards from the last page to find it
Posted : 15/03/2015 3:16 pm
Been using Alpine quest for a few years with all my qct files. Works fantastic. Also tend to save aerial photos of interesting areas to use together with the maps. To use mmo files you just need to "save as gpx" inside memory map.
Posted : 15/03/2015 5:34 pm
MMTracker installed and seems to work 😀
Posted : 17/03/2015 3:43 pm
