Using a double spec...
[Closed] Using a double specific crank for 1X?
Is the chainline completely out of whack with this setup?
A Shimano M8000 double has a 48.8 mm chainline which as a single would work out as a equivelant 51.8 mm single chainline.
Any OPEX?
Can get one considerably cheaper than single to background question
Posted : 10/12/2017 8:24 pm
The M8000 double crank is the same as the M8000 single crank. There's no difference in the chainline.
Posted : 10/12/2017 8:26 pm
Ive never had any issues with it, just mount it in the middle ring spot and bobs yer uncle
Posted : 10/12/2017 8:27 pm
scotroutes, that was my understanding until I read [url= https://int.oneupcomponents.com/pages/understanding-chainline-for-optimal-1x-conversions-boost-and-non-boost ]OneUp components guide to 1X[/url]
Posted : 10/12/2017 8:30 pm
I run a single ring on numerous double cranks and I've never noticed any detriment to shifting.
 core
I'm running an slx double in a 1x setup on a boost 148 frame, I think that gets it within 1 or 2mm of where a boost specific 1x crank would be.
Posted : 10/12/2017 8:43 pm
I find it better, although in theory the chainline is a couple of mm outside dead central whereas a triple in the middle position would be spot on, with an 11-40 10 speed cassette most of the gears i ride are to the outer part of the cassette (say 5-6-7-8) so the chainline is better for them.
It does mean that the low gears on the cassette are a little cross chained but they are climbing gears and bail out mainly anyway. Might be different if your riding is hillier.
Posted : 10/12/2017 8:59 pm
[quote=guitarhero ]scotroutes, that was my understanding until I read OneUp components guide to 1X
If you buy a 1x Shimano M8000 crank and install a ring in the "big" position it'll be about 52mm. You can install a small spacer/shim to move it in a little but, in practice, it seems to make no difference.
FWIW I run a 2x non-Boost M8000 crankset on a Boost frame and it's fine.
I also run a 1x non-Boost M8000 crankset on a non-Boost frame - and it's also fine.
Posted : 10/12/2017 9:04 pm
