Upload to strava - ...
[Closed] Upload to strava - sync to Garmin Connect?
Morning folks,
Quick question. If I upload a ride directly to strava is there a way to make Garmin Connect sync this ride also?
I know it works the other way around.
Thanks
Posted : 16/09/2015 10:10 am
Tapiriik should do it, I haven't used it for ages though.
https://tapiriik.com/
Posted : 16/09/2015 10:17 am
Presuming you are using a Garmin device you can sync with Garmin connect and then get strava to pull it in automagically.
If you're using a device and going straight to Strava then the above should help.
Posted : 16/09/2015 10:23 am
Thanks both.
I'm uploading directly to Trainerroad (broken collarbone recently so no riding this year) and Strava pulls it directly from Trainerroad. I was hoping Garmin would pull it from Strava or Trainerroad automatically but it appears not.
I'm not using a Garmin device, just the Trainerroad app on my iPad. I normally just use Garmin Express.
The Trainerroad app is excellent btw!
Posted : 16/09/2015 10:41 am
 Haze
TrainerRoad sync to Connect is apparently in the pipeline...
Posted : 29/09/2015 10:57 pm
