Upgrading from quic...
[Closed] Upgrading from quick release.
 Xan
Havin been toying with the decission of a wheel upgrade for a bit. I would like something a bit stronger than quick release but is this possible without upgrading my 2007 Talas RLC's
Posted : 03/08/2009 3:56 pm
Going to bolt-thru (20mm or 15QR) would mean at least new lowers or new fork.
The only other decent alternatives I've seen is the DT RWS system, particularly the thru-bolt version:
http://www.dtswiss.com/Products/Components2009/RWS/RWS-thru-bolt.aspx
Posted : 03/08/2009 4:16 pm
I've heard you can get new lowers for a not-extortionate amount.
Give Mojo a bell and ask them.
Posted : 03/08/2009 4:20 pm
i have a qr version from chumba of the 9mm thru axle, cheap and cheerful and noticeably stiffer
if you have hope pro2s, halo combats, some bontrager, dt swiss wheels adapters are available
Posted : 03/08/2009 4:22 pm
 Xan
Thanks I'll have a look into the DT Swiss stuff. Really wanted to go Hope Pro II but doesn't look like I can do that without a change of lowers.
Phones Mojo and they want £250 for new lowers and a service. That plus the £250 for the wheels makes it an exspensive nice to have at the moment.
Posted : 04/08/2009 8:07 am
no you can. hopes are qr/ bolt thru convertable for about £15. buy the wheels buy the forks later and chnge the hubs to bolt thru.
HTH
Posted : 04/08/2009 8:16 am
9mm cheap and cheerful upgrade (checout the last pages):
http://www.singletrackworld.com/forum/topic/can-you-get-9mm-bolt-thru-adaptors-for-hope-pro-2-hubs
Are all models of pro 2 convertible between qr and 20mm?
Posted : 04/08/2009 8:41 am
all models? Pro 2 is Pro 2.. so yes they're convertable between:
Front
STD QR
9mm thru axle
15mm thru axle
20mm thru axle
Maverick fork axle
Rear:
STD QR
10mm thru axle (135mm)
12mm thru axle (135mm)
Posted : 04/08/2009 10:33 am
