Community
Upgrading from 9 sp...
[Closed] Upgrading from 9 speed to 10 speed ?
What do I actually need.?
Currently running slx 9 speed and want to upgrade to 10speed xt.
Do I really need to buy a whole new groupset?
Posted : 01/09/2012 6:39 pm
 br
tbh I'd only do it if you need to replace chain/rings/cassette anyway, and groupset is probably the cheapest/easiest way if you need to ask the question
Posted : 01/09/2012 6:44 pm
If you want to change everything to XT, you'll need shifters, crankset, chain, deraileur, cassette
otherwise just a RH shifter, chain and cassette - I think
And rear mech
Posted : 01/09/2012 6:49 pm
Well my chain is well worn that's all and the cassette has been on for 18 months or so, so I think it's due.
Posted : 01/09/2012 6:56 pm
you can use your current 9 speed rear mech i think.
Posted : 01/09/2012 7:54 pm
No, you can't, hence my earlier post.
Posted : 01/09/2012 7:56 pm
 br
[i]Well my chain is well worn that's all and the cassette has been on for 18 months or so, so I think it's due. [/i]
You get 18 months from a cassette ๐Ÿ˜ฏ How few miles do you do?
Posted : 01/09/2012 8:04 pm
You get 18 months from a cassette How few miles do you do?
As long as you don't do anything daft like change the chain, they'll last forever ๐Ÿ˜€
Posted : 01/09/2012 8:06 pm
It was on my spare bike which has now turned into my main bike !
Posted : 01/09/2012 11:03 pm
No, you can't , hence my earlier post.
Why not? Different cable pull?
Posted : 02/09/2012 2:40 am
Yes
Posted : 02/09/2012 9:34 am
But can you use a 10sp mech with 9sp shifters & 9sp casette?
Posted : 02/09/2012 10:17 am
No (well not unless it's a road one)
Posted : 02/09/2012 10:20 am
Ta.
Bum.
Fancied a Zee but didn't want to change everything else.
Might have to be a Saint then.
Posted : 02/09/2012 10:36 am
10 speed road (sti) works fine with 9 speed xt rear mech on 11/36 where the 10 speed xt rear wouldn't - is it a different pull, have you tried it?
Posted : 02/09/2012 11:14 am
Yes, it's a different pull.
7,8,9,10 speed road and 7,8,9 speed Shimano rear mechs all use the same pull ratio.
10 speed Shimano mtb rear mech uses a different pull ratio and needs a 10 speed Shimano mtb shifter to work.
Posted : 02/09/2012 11:17 am
I would replace the lot, tbh groupset will probably be cheaper than buying 2/3 groupset separately.
You could prob get away with the front mech, but it's slightly wider which makes setting up a little bit tricky.
Posted : 02/09/2012 12:42 pm
