UDH hangers- any re...
UDH hangers- any reason not to just buy a SRAM one?
Not really interested in a Burgtec at £30+ unless it's radically better. Could do with a spare or two so SRAM or an alternative? Thanks in advance...
Posted : 27/01/2024 9:20 pm
If this is to fit to a trek, yes. Whilst a UDH does fit, the trek one has a larger diameter inner (or is is outer) that doubles as a suspension bearing cover/seal.
Posted : 27/01/2024 9:35 pm
It's not a Trek, but that's good to know.
Posted : 27/01/2024 9:37 pm
Nukeproof do two versions I think- a stronger version as an option that doesn’t cost much more.
Posted : 27/01/2024 9:56 pm
 Aidy
Surely the hanger is supposed to be sacrificial? i.e. stronger isn't better
Posted : 27/01/2024 10:53 pm
binman, zerocool, binman and 1 people reacted
I think it rotates. It’s not really sacrificial. And there’s not a sacrificial bolt either.
Posted : 27/01/2024 10:58 pm
Well it is supposed to rotate yes. Mine rotated and bent. Replaced it with a stronger one. Which rotated and then the derailleur mount snapped.
Posted : 28/01/2024 11:33 am
kelvin and kelvin reacted
Isn't the whole point of them that they're meant to be interchangeable?
Posted : 28/01/2024 11:35 am
@reeksy the mount on the frame snapped? Or the mech? That doesn't sound good either way 🙁
Posted : 28/01/2024 2:35 pm
The goat link
Posted : 28/01/2024 7:50 pm
Isn’t the whole point of them that they’re meant to be interchangeable?
I expect you can improve on the standard as long as the frame can take a standard UDH, and perhaps too that your UDH will fit any frame.
Posted : 28/01/2024 8:27 pm
Wow, Trek, talk about missing the point!
Posted : 29/01/2024 10:17 am
Wow, Trek, talk about missing the point!<br /><br />
Never had a Trek I take it? They love taking easy stuff and making it complicated. They have an entire department who’s job it is to make proprietary parts to solve problems they invented.
Posted : 29/01/2024 10:40 am
I don't think they're really missing the point, just following Sram's design.
If the design relies on bending not just rotating... what happens with a Transmission derailleur?
Posted : 29/01/2024 10:43 am
If the design relies on bending not just rotating… what happens with a Transmission derailleur?
Transmission can rotate as per UDH.
In bending, the loads from the transmission derailleur is transferred into the thru-axle and not the frame as a lot of people believe, which is why it's significantly stronger than a traditional derailleur hanger setup.
Posted : 29/01/2024 11:45 am
Exactly, it's designed to rotate, not bend in a sacrificial way. That's the UDH design. So stronger is "better" as per the design. Still not sure about it myself, but it's a different approach... people can't expect them to bend (or have a sheer bolt fail) to protect the frame... that's not the idea behind them... they are not like the replaceable hangers we've been used to for decades.
Posted : 29/01/2024 12:31 pm
