Uberbike floating d...
[Closed] Uberbike floating discs - out of true from new
[#9524906]
Hi,
Quick question - is this normal to have brand new discs to be slightly out of true? Is there a tolerance that is acceptable? or do I accept them as they are and think if it doesn't bother me apart from the scritch scritch as I ride down the street
Also if the wheel is slightly untrue - is this a factor?
Thoughts to put my mind at rest before I return them,
Kwack
Posted : 31/08/2017 7:48 pm
Would probably be easiest to straighten them yourself.
Posted : 31/08/2017 8:36 pm
were the flange faces clean when you bolted it on? Untrue wheel wont affect it
Posted : 31/08/2017 8:45 pm
Yeh the disks bolted to the hub and the hubs bolted to the fork so an untrue wheel shouldn't really affect it unless it's really untrue.
Put the disk on a flat surface and bang it flat with a rubber mallet or something.
Posted : 31/08/2017 8:55 pm
 cnud
I've had 4 of the 203 floaters, all needed straightening. As DT says, I found it easier to do myself rather than send back
Posted : 31/08/2017 9:37 pm
If you bolt them to your wheels, you should be able to tweak them with an adjustable spanner. Don't hit them with a mallet.
Posted : 31/08/2017 9:44 pm
Thanks for the replies.
Will give em a tweak with a spanner when I put em back on again
Kwack
Posted : 01/09/2017 7:41 am
I've always found that when I straighten a disk it normally goes back after I've used it.
Are you sure it's not straight? Did you put it on a flat surface to check or are you going off the fact it's it straight after you bolted it to the hub?
Posted : 01/09/2017 9:09 am
After bolted to the hub - i did lay it on the table and it felt ok maybe some slight movement
Posted : 01/09/2017 9:32 am
Bought some for an old bike, they went rusty in 6 months, I removed them again and replaced with the Hope ones on that I should have bought in the first place.
They weren't out of true though, and I've since cleaned them up for temporary use on my son's bike until I can get around to replacing them.
Posted : 01/09/2017 10:14 am
