U-turn adjust the t...
[Closed] U-turn adjust the travel range?
I want to adjust the travel range on my u-turn forks from 120-150 to 100-130 (or 110-140). Can this be done in the same way as non-u-turn forks?
2010 Revelation Race, if it matters.
ta,
thebunk
Posted : 28/07/2010 1:22 pm
don't thinks so - not on the coil ones I have anyway
Posted : 28/07/2010 1:28 pm
No. Not possible.
Posted : 28/07/2010 1:29 pm
put 20psi more in the neg than the pos and they will sit at 140mm and when the u turn is would down it will be at 110mm.
this is what I did with mine.
Posted : 28/07/2010 1:35 pm
 GW
just stick an old rev/pike uturn spring in and it'll work.
Posted : 28/07/2010 5:07 pm
