A definitive list, I'll start....
Bontrager AW3 on Mavic Aksium, has taken my feeble thumbs an hour and a half to fit, and has cost so far; 3 inners (keep pinching them) and a park tyre lever (I have never in my life snapped a park tyre lever!)
bin em, what happens if you get a puncture out the house, when its raining and cold, and raining a bit more
It's probably just one of those combinations, but Check the rim tape. I had a tyre I couldn't fit, turned out the rim tape was too thick
Conti RQ's were quite a hassle to fit on DT rims.
I'm finding Conti CX tyres quite tight on Wheelsmith rims - 30 mins and a punctured new tube. Suggestions welcome for slightly less tight brands.
Bonty xr4 TLR were a pig to mount on flows when new.
But refitting a month later after removal were not to bad.
Hans Dampf on Stans Arch EX.. nightmare!
I struggled (several punctures) to get some race tyres onto my road bike then watched a few Youtubes about doing it with no tools. Result!
I'll call your Dads and get them to help.
Lots of stuff online about Geax Saguaro TNTs on Stans rims.
The non TNT versions are OK however and are fine tubeless.
Tell him not to forget his best tyre spoon.
Conti wire cx tyres on Crest 29er rims
They'reon now, with tubes, and I still can't get the bead to seat properly.
at the other end of the scale - old michelin All Terrain 2.4's on mavic 719's, slacker than a fat slag from middlesborough who takes it up the wrong 'un. that bad that i needed help to hold the tyre on the rim to inflate, and the tyre rotated under heavy braking ripping the valve off 6 times in one ride!
Schwalbe NN, WW or FA on a Sun EQ27 rim - absolute bloody nightmare to get on! Broken tyre levers, lots of sweating and plenty of swearing!
Hans Dampf on a Mavic cross roc was a but tight.
Used a tea spoon in the end as i'd killed both my tyre levers
gear Saguaro tnt and stan's +100
Hans Dampfs on DT Swiss ex5.1d. Nigh on impossible with rim tape of any thickness, still really bad without tape. They're fine on 729s though!
