Tyres for a heavy r...
[Closed] Tyres for a heavy rider - Apologies in advance
I've read the reviews, looked at what other people use and all that but I've some very specific requirements.
I can't really run tyres at less than 40PSI, pinch flats or worse result. I'm after some grippy winter tyres 2.2 size (2.35 Max for clearance) for XC woodland riding in all this sodding mud any ideas please? Don't really want to spring for black chilli contis but thinking I might have to.
Posted : 14/01/2013 10:02 am
Go tubeless so no more pinchflats.
Posted : 14/01/2013 10:12 am
A 95kg racer writes...
Avoid Continental, they seem to develop mysterious bulges in the sidewall when I use them.
I like Michelins, they've got the best reputation for truck tyres, yet they are unfashionable on mountain bikes, which makes them cheaper than other brands of similar quality.
Posted : 14/01/2013 10:18 am
100+ kgs here and ride Schwalbe Hans Dampfs...
Posted : 14/01/2013 10:19 am
Michelin Wild Grippers 2.2 for me, always run them tubless & never get pinchflats, just the occasional ripped tyre on proper rocks, never use more than 30psi. Not a mud tyre but a decent compromise.
Posted : 14/01/2013 10:24 am
Use conti's. I've run them for years never had a bulge issue.
I stil rate the vertical as a top all rounder.
the protections help with pinch flats and they will convert to ghetto tubeless.
Mich all mountains are a solid tyre, but be ware that they can come up big, a 2.0 is a 2.2 by most standards.
Posted : 14/01/2013 10:36 am
 ton
maxxis dual ply. well worn minnions are the best.
Posted : 14/01/2013 10:43 am
Have you considered heavier tubes? My mate likens my landings to a baby elephant being dropped from a chopper. I'm about 85 kg, used to get lots of pinch flats, but now I use maxxis fr or dh tubes, and dual ply maxxis hrs, havent had a puncture in 2 years . Alps, spanish sharpened marbles with switchbacks, dartmoor granite, fod roots. Not a single flat.
Posted : 14/01/2013 10:45 am
I've got verticals now with a BC up front and a protection out back, the back one is worn out so I must have spun out an extra 10 miles yesterday really trust the front one though. I use heavy tubes but find my tyres squirm about at less than 40 PSI, it disconcerting. I was thinking I might go for a BC Queen out back.
Posted : 14/01/2013 11:22 am
95kg, 2.2 Spesh Purgatory's run tubeless at about 27-30 psi.
Grip is great, but doesn't like running higher pressures for some reason (35psi and it's like riding on ice).
Verticals are beyond crap IMO. And heavy tubes and 40psi is some serious puncture protection. Try some newer tyre designs, and tubeless at ~25-30psi, you'll probably be amazed at the difference.
Posted : 14/01/2013 12:55 pm
Over 110kg here and had loads of different Bonty tyres (tubeless ready and normal) with no problems at all. Better than the Hutchinsons I've had.
If you weigh enough, you'll push any tread through the gloop to where it will grip 😀 I know I get traction where lesser (weight) men have failed.
Posted : 14/01/2013 1:14 pm
Single-ply Contis are more prone to punctures than Maxxis, but less so than Kenda IME.
I'd try something from Maxxis with the Exo sidewalls if I were you, or the On One Smorgasbord which they suggest is a Maxxis Exo carcass with their own tread design (and pretty cheap).
Posted : 14/01/2013 1:23 pm
I'm 82Kg and been using Conti Mountain Kings (the basic folders, none of your Black Chilli or ProTection bobbins) for years, no problems.
At risk of getting shouted at, if you pinch-flat a lot, maybe have a look at your riding style...???
Posted : 14/01/2013 1:40 pm
I agree on riding style also. I'm 120 kg and used to pinch a fair bit running low pressure, changed style a bit, trying to be softer on landings ect and not been bad, I bought some ust rubber queens by mistake, that have a very thick sidewall and roll well after converting my rims to tubeless, I also have non ust black chilli ones, only just put one on the back so far, seems good but sidewalks are very thin
Posted : 14/01/2013 2:21 pm
Also ment to say, I used duel ply super tacky minions when we went to morzine last year and they are absolutely brilliant, not one flat compared to others in the group that had several! However they are heavy, oh so very heavy, almost killed myself just doing a lap of Llandegla before we left for France. So as good as they are I'd only recommend them if you have uplift
Posted : 14/01/2013 2:25 pm
100+ kgs here and ride Schwalbe Hans Dampfs…
I doubt he'd fit these in with the clearance hes mentioned, I just tried to swap my high roller 2.35 for a hans dampff 2.35 and it had about 1mm clearance, rubbed round corners so had to swap it onto the front. Don't think they do narrower versions. Good tyre for the front though…
Posted : 14/01/2013 2:40 pm
I am 19st stone and ride at between 6 and 12 PSI dependent on the terrain.
Posted : 14/01/2013 2:47 pm
 Del
on-one smorgasbord are so cheap they're worth a shot for sure.
Posted : 14/01/2013 2:48 pm
Posted : 14/01/2013 2:51 pm
Based on all these comments and an element of being a mug to the hype I've ordered some BC rubber queens, when the rear one doesn't fit it'll be up for sale!
I think these with some burly tubes and I should be all set bit eye watering pricewise though.
Posted : 14/01/2013 2:55 pm
Eh? You sure?
Posted : 14/01/2013 2:59 pm
fatbike..?
Posted : 14/01/2013 3:03 pm
Mantastic - Member
REALLY? I would have thought the tire would be flat at those pressures. Is that what the pump guage reads?
Posted : 14/01/2013 3:07 pm
Mantastic - Member
fatbike..?
Posted : 14/01/2013 3:08 pm
140kg here.
Conti are rubbish IMO. Squirm all over the place no matter what compound.
Maxxis are ok as long as you use the maxxpro- if you're heavy then the compound won't matter as you'll dig into any terrain anyway
Schwalbe are my favourite, I use racing Ralph's on the xc bike and a mixture of big Betty's, muddy Mary's and dirty dans on the dh bike.
Michelin are also very good. Have used the wild dig'r and rock'r with no problem. Just harder to find for reasonable money.
Posted : 14/01/2013 3:20 pm
Seems MTB is for the waifs, if you're over 110kg you can forget about working suspension or low pressure tyres...
Posted : 14/01/2013 3:23 pm
 D0NK
I'm not heavy but I do ride heavy. Minions is my choice, double ply rear run tubeless, single ply sticky upfront.
It is [i]extremely[/i] annoying having to run tyres so hard just to prevent flats, 21st century and we still can't keep air in tyres.
Currently getting lots of flats on my new CX bike, tubeless beckons
Posted : 14/01/2013 3:37 pm
Perhaps learn to ride a bit lighter with more finesse?
Posted : 14/01/2013 5:31 pm
never had problems with schwalbe's.
Posted : 14/01/2013 5:34 pm
I'm just over 100Kg and find that Schwalbes work pretty well for me.
Much better than the Maxxis tubeless tyres I'm running at the moment anyway!
Gotta love the trolls.
Yeah ride lighter that'll solve it!
Posted : 14/01/2013 6:27 pm
The geax datura wouldn't be a bad buy, tubeless (well, some are) well grippy in the mud and have a tough sidewall. Not expensive either from on one.
Posted : 14/01/2013 8:08 pm
a good dusting of talc is meant to help if you don't fancy tubeless
Posted : 14/01/2013 8:12 pm
