Tyre Volumes
[Closed] Tyre Volumes
How does a 2.35 Schwalbe Nobby Nic compare to a 2.2 Continental Rubber Queen?
My NN is squirming at lower pressures when run tubeless, so was thinking that moving to a narrower tyre (RQ) might help. But I still want a fair bit of volume, and have heard that the RQs are really tall, so volume may be the same if not greater than the NN.
Posted : 10/04/2014 12:22 pm
What size is that, 29? 2.4 26er NN is probably very similiar to a 2.2 RQ if that's any use, as you say the RQs are taller than most.
But RQs are sort of similiar to NNs in that they've got pretty thin/unsupportive carcasses, so I think you're quite likely to still find them squirmy at really low pressure. Though having said that, my RQs were the original version with no sidewall protection or ust-ness or anything and an appetite for falling apart so maybe newer ones are beefier.
Posted : 10/04/2014 12:26 pm
There is the try more air in it option.
Posted : 10/04/2014 12:29 pm
They're 26", and would be looking at getting the protection, etc or a UST version, so will be more resistant to squirming.
Would like to run higher pressures, but due to back injury (2 bulging discs) I need them low to take edge of the trail chatter on my hardtail. Ideally I'd buy a full susser, but that's for inclusion next year's budget.
Posted : 10/04/2014 12:39 pm
