Tyre clearance on r...
[Closed] Tyre clearance on road bike.
 WTF
Thought I would try a Schwalbe G One 30mm tyre on my road bike that I use for a bit of everything really but mostly commuting along canal towpath.
Used to run 25mm on this but never really noticed how little clearance there is until I fitted this.
Clearance is better at sides but took some pics of the top to try and show this.
[URL= http://i41.photobucket.com/albums/e295/viw22271/IMG_3029_zpsebj1uwa7.jp g" target="_blank">http://i41.photobucket.com/albums/e295/viw22271/IMG_3029_zpsebj1uwa7.jp g"/> [/IMG][/URL]
[URL= http://i41.photobucket.com/albums/e295/viw22271/IMG_3027_zpswyatp8ii.jp g" target="_blank">http://i41.photobucket.com/albums/e295/viw22271/IMG_3027_zpswyatp8ii.jp g"/> [/IMG][/URL]
Will a 28mm Schwalbe Pro One for example be a big difference or will I still be in danger of superman re-enactment or alternatively if someone could recommend me a fork (possibly carbon) that would have better clearance, even enough to fit a mudguard under maybe?.
Its a Cannondale CAAD 9
Posted : 05/02/2017 1:01 pm
I wouldnt run that, as soon as you hit something and it squashes the tyre down it will probably rub the sides, eventually going right the way through the fork...
Posted : 05/02/2017 1:06 pm
+1 Wiggles, and/or it'll 'just' grind massive grooves into your fork crown. I've got a 28mm One on the front of my road bike (a racey carbon Lapierre), which actually measures 30mm due to being on a noo-skool wide rim, and whilst it is tight it is better than that (but still close enough that I heli-taped the underside of the crown to stop it getting trashed).
Posted : 05/02/2017 2:13 pm
 WTF
Off it goes then!
Unless I can find fork that suits it better although that's not so easy to buy one then find out I have same issues.
Any recommendations would be appreciated.
Posted : 05/02/2017 2:39 pm
What's the clearance like on the rear wheel?
Posted : 05/02/2017 2:47 pm
Can you run 30mm at the back, where the proportion of weight is greater and the additional volume will give you some cushioning, and 25mm front?
Posted : 05/02/2017 3:16 pm
not the OP but for Timba I had more clearance on the front than the rear, I have a 25 on the back and a 28 on the front. I'd initially thought of putting it on the rear with the cushioning argument, but having put it on the front like the more-cornering-traction argument.
Posted : 05/02/2017 3:28 pm
Have you ever seen how fast a muddy tyre wears through carbon or even metal?
Posted : 05/02/2017 3:37 pm
 WTF
simondbarnes - Member
Plenty, just wanted to up the size all round as much as possible to make it more comfortable.
Possible carbon fork upgrade to take a bit of the shock.
Posted : 05/02/2017 4:04 pm
im no expert on road bikes, but i wouldnt (knowingly) ride that
Posted : 05/02/2017 4:39 pm
