Turner flux - how w...
[Closed] Turner flux - how would you build this up?
If you were gonna build up one of these:
what kit would you put on it?
100/120mm forks, full SRAM XX? what colour scheme? just keep it black accessories, or white forks, or maybe blue X.0? or just keep it simple?
Not that keen on the look of the build on the turner website, I am sure it rides amazing but too me its aesthetically lacking something, or maybe the red clashes, or too much black?:
Posted : 11/05/2012 11:55 am
I'd go 120 fork (maybe uturn to give the option of going 100mm) I wouldn't go sram xx as it will never be a weight weenie.
it has a black shock so i would go black fork & rims too.
keep it simple ๐Ÿ˜‰
Posted : 11/05/2012 12:01 pm
What are you using the Flux for? As a general bike for everything, 120mm forks, 70mm stem ,wide'ish bars.
Depending on budget, either
- Shimano SLX group with brakes, 10sp 11-36t, triple
- Shimao XT group with brakes, 10sp 11-36t, triple
- SRAM X0 group, with XTR X985 brakes, 10sp 11-36t, triple
Simples ๐Ÿ™‚
Blue shifters and mech would be too much IMO. Red would be pretty nice, or black, as accents.
White fork... maybe, if so then you'll need white rims - or it will look a bit odd with black rims and white fork.
This is all aesthetics, and most of the STW massif will hate you for it, and tell you to just go ride.... which is very true to be honest.
There's an MTBR thread about 'show us your turner flux race build - this http://forums.mtbr.com/turner/lets-see-your-dw-flux-race-bike-589316.html
May be of use.
Ricks
Posted : 11/05/2012 12:03 pm
heres mine [IMG] [/IMG]
around 27lb
black fork
quite a bit lighter with the sid's and normal post (probably around 25lb ish
Posted : 11/05/2012 12:12 pm
Thats nice, really like the "look" of the blue frame for something different, but maybe the Raw of the black are safer options.
Although there is a new red one coming out:
Posted : 11/05/2012 12:14 pm
merlin had a nice orange one in yesterday - looked great
sounds like your into the looks of your bikes - I'd suggest raw as you dont have to worry about scratches & chips ๐Ÿ˜‰
Posted : 11/05/2012 12:16 pm
image is everything when you know nothing.
Don't we all want the bike to look good though as well as performing well?
Posted : 11/05/2012 12:32 pm
Just built on with white DT Swiss XMM 120 forks and it look really good even if I do say so myself. ๐Ÿ˜€
Posted : 11/05/2012 12:46 pm
I always go black - looks good and parts can be changed to other frames etc.
I will be tempted by a deal though ๐Ÿ˜† (hence the silver forks)!
Posted : 11/05/2012 12:47 pm
I'd build it just like this.........
oh. I did. ๐Ÿ™‚
Posted : 11/05/2012 12:52 pm
120mm white fork. They suit Maguras. SRAM XO. Silver hubs, rims (optionally white) and finishing kit.
Posted : 11/05/2012 2:05 pm
My flux is a chameleon.
General trail - 700mm riser bar & 60mm stem, hope pro2/flow rim wheels with high roller/advantage tyres, ks dropper post.
Marathon/XC SDW in a day type setup - 620mm flat bar and 90mm stem with ergon grips and normal post with hope hope3/crest rims and light racy tyres.
10mins to switch between the two.
99% of the time use a SID fork shortened to 110mm which is great. I do switch to a pike u turn fork turned down to 120mm every now and again.
Posted : 11/05/2012 2:40 pm
funny how many people are saying white rims, and my white rims on my CX build got a slating on here?
http://singletrackworld.com/forum/topic/my-crosslight-build-update-pics
different strokes for different folks ๐Ÿ™‚
Posted : 11/05/2012 2:51 pm
White revelations spaced down to 130
Black Arch EX on Pro 2s
Easton odda and ends
Schwalbe Nic front/Ralph rear
XTR cranks & XT/SLX everything else
Posted : 11/05/2012 3:02 pm
Sorry to butt in on your thread guys, but I'm on the cusp of either buying a flux or a 5.Spot and am torn between the two. In brief I'm 6'3", weigh 16 stone (I know) and mainly like to throw my bike around on red/black run in places like Llandegla and Coed-y-Brenin, though I am also looking at doing longer distance rides in peaks and pennines. I've been riding a Cannondale hardtail. Totally sold on Turner frames, but don't know whether greater travel/slacker angles of 5.Spot would be better for someone my size. Any thoughts would be much appreciated.
For what it's worth, I'd stick to black on the build side, but ultimately its all a matter of personal taste. Cheers!
Posted : 11/05/2012 3:22 pm
I have "been on the cusp" for a while now ๐Ÿ™‚
I am no expert but to me it sounds like the 5-spot would suit you better, or maybe even a sultan?
this thread should help you decide:
http://singletrackworld.com/forum/topic/turner-flux-or-5-spot
Posted : 11/05/2012 3:27 pm
how much slacker are the 5 spots though?
I would say a 5 spot would suit your needs better though.
there's a few that ride 5spots around the pennines on here
Posted : 11/05/2012 3:28 pm
Also, forgot to say, when I fitted a works components 1deg angleset to mine it definately felt better in "general mode". Not chalk and cheese, just a bit better [u]for me[/u].
Posted : 11/05/2012 3:31 pm
Thanks guys. have looked at the Sultan, but am desperately trying to keep a lid on costs for the build and the thought of shelling out for new wheels/tyres etc gives me the willies. Concern is about the 5 being a bit cramped. Its Reach and effective TT are shorter than the Flux and way shorter than a "short" bike like the Transition Bandit (any thoughts on them by the way?) With the way my riding is going I can see that the temptation to throw whatever I get off ever larger drops will be very real, which I suppose discounts the Flux?
5 Spot is 1.5 degree slacker head angle and 1 degree seat.
Posted : 11/05/2012 4:12 pm
 nuke
One thing I felt the Flux could do with, particularly if you doing smallish drops/jumps, is a Fox air spring volume tuning spacer...the Flux has a very plush ride but, I found, on certain descents it would to easily use up its travel. However if I increased the shock pressure, I'd lose the plushness of the ride. With this in mind, I reckon a tuning spacer that would cause the air pressure to ramp up in the final part of the travel would be an improvement. Shame I only realised you could get tuning kits after I had sold my
Flux ๐Ÿ™
Posted : 11/05/2012 4:30 pm
Hi guys, struggling to see way forward in 5spot v flux conundrum without at least sitting on one, but can't find anywhere with test bikes. So, any of you guys a) based in north or midlands, b) have a 2009/10/11/12 spot or flux and c) would be prepared for me to have a look and/or a quick spin (round carpark or somesuch). Really want to get a feel for position etc. In return happy to stand a round or three....let me know, cheers!
Posted : 12/05/2012 11:34 am
Don't get white rims - they look gash. Understated is the key to a nice looking build ๐Ÿ™‚
Posted : 12/05/2012 11:58 am
Should add re my previous post, the size I would need to look at is XL. Cheers
Posted : 12/05/2012 12:03 pm
f120 15mm
xt 10speed 1x10
70mm stem, 711 bars
crossmax st
all black
Posted : 12/05/2012 2:15 pm
