Thanks all for the feedback.
Heihei, I do like the look of the mojo hd, especially with the 140/160 options. A while ago it was a toss up between that and a burly blur ltc build. Gone off the boutique carbon thing a bit now and loving the industrial look of the nicolai. Rode an AM at Afan a few months back and it was amazing on the downs. Didn't feel that good on the ups, though I'd just come off a long ride on a 100mm xc bike so really need to be compare it against more similar bikes.
Had a go on a five the other day too. Seemed very good at the xc stuff though was set up for a rider about 4st heavier than me so probably not the best test of the single pivot.
Bringing it back to the 5 spot, anyone know anywhere that does proper test rides around Berkshire area?
I know these guys used to do demo's http://www.mountain-trax.com/
Mine is 2 years old and has laughed at everything I've thrown at it.
[IMG]
[/IMG]
I bought my DW from Mountain Trax - as above they used to have a demo, dunno if they still do. The Helius AM may be overkill - I'd go with the AC which can build into 28lbs or less. Head for the Hills have a demo AC in Dorking.
I don't think mountain trax do them anymore. Must demo their LT and 575, maybe the orange too.
Would be torn between the AC and the AM. If I could run an AC with 160 forks then I'd definitely go that route. Seem to remember reading about someone who got a custom AC built with some AM bits so that they could run a 160 and not void the warranty. Must dig that out.
ChunkyMTB, nice build btw. Would be much how I'd build it. How do you find the BB chain guide working?
In STW style I have to point out that your seat is rather far forward on its rails and your tyre logos are not properly aligned 🙂
BB stinger works fine never had any issues. And for the record, saddle is bang on in the midle of the rails guides - you need better eye sight 😉
Try Nirvana nr Dorking for a demo 5-Spot. If you plan it right, you could test that, then the AC from HftH. HftH are also Ibis dealers and can get hold of 2-Pure's demo HD in if you wanted (or can try mine).
Yes Nicolai will do custom, but does cost quite a bit more. If you went down the Nic route it's worth hanging out in the MTBR forum as lots of helpful and knowledgabe folks on there. Geetee1972 on here owns a Helius AM with some custom geom, but says if he got another Nic he would get an AC again with some custom geom.
I own DW 5 spot. Had a few decent FS bikes the last being an Ellsworth epiphany. It weighs in at 28lbs (is that heavy or light for a 140mm trail bike?) I find it great for all my riding. The frames are so stiff, honestly you can feel the diffrence. As for the head angle being a couple of degrees steeper.... Its still fairly relaxed and climbs well, feels comfortable with a 70mm stem without wandering around. And decends really really well.
Heres mine on the gondola at Fort Will getting ready for a few runs down the DH track.
[IMG]
[/IMG]
Go demo the 2011 5 spot it f'ing rocks 🙂
""Too slack = too slow on fast and tight singletrack!"
True, but its a stiff 140mm FS, is being too slack for tight singletrack that big a concern?
Older (at least 2009?) DW 5spots were 69deg with a 140mm fork, which is about the steepest you can get a bike designed around a 140mm fork
The 100mm Flux DW has a 70deg HA with a 100mm fork, so front end bottomed out (say as you go over the bars on something steep - where the rear is fully extended) or with a 140mm fork the 100mm flux is actually slacker than the 5spot? Surely the 'need' for the 140mm 5spot to be nimble in tight singletrack wasn't so great that it was made steeper (with equivalent fork) than the 100mm flux?
Newer (current) DW 5spots are more middleground with a 67.7deg HA with 150mm fork
"the Mojo and couldn't afford one if I did!"
I thought a mojo about the same as a blur lt and a bit less than a 5psot?
"head angle is more suitable for long rides with plenty of climbing compared to many bikes with slacker head angles. DW link is great for saving your energy over the course of a day's ride"
In this regard the stiffness and weight of the frame aren't a help though?
There are other lighter (almost 1-2lb lighter) DW 140mm frames about for about the same or a bit less money (eg ibis mojo/mojo sl/mojo hd 140)
"you want it for alpine duties as well as general XC stick some Fox 36 Talas' on the front"
Now they only them in 160/120mm, not 100-130-160mm, they won't work as well on 140mm bikes. That leaves you with 'well heavy' RS Lyrik coil U-turns
"there seem to be a lot of happy 5 spot riders out there"
Probably because the thread has 5spot in it?
"can you get the Reign as a frame only?"
They used to be available for £800, but since they've slackened them (from 69deg with a 140mm fork) I think they've dropped them frame only
"sektor; coil, with 110 to 150mm adjustable travel"
1[b]05[/b]mm to 150mm surely?"
I realise there could have been a certain slant on it, but I went to an IMechE talk by Cy Turner (of Cotic) not so long ago and the comparisons of the 150mm hemlock with the 5spot, mojo, 5, blur lt etc were pretty interesting, especially the theoretical linkage driven single pivot 'hemlock' vs. a DW 5spot
If you can get past the 'looks' and 5psot sort of weight (it is £1100, can take 160mm forks and the new chainstays are 1/2lb? heavier) then going by the ST review it looks pretty good
When I changed bike 3 years ago I narrowed it down to 3 options and test rode them all within a week to get a direct comparison. If you can possibly sort it, it's just much easier to make the decision when they are all fresh in your mind.
Definitely get a demo on the BLT2 - it's superb, and actually climbs best with the propedal off. With a 36 Talas on the front head angle will be a smidge more than 67 deg; wound down to 120 it would be around 69 deg, so good for climbing.
The BLT2 encourages a bit of hooligan behaviour, and seems indestructible. The new VPP system is pretty maintenance free. In 3 years of Scottish all weather use and lots of big rocky descents, the top bearings have just had to be replaced, but parts are FOC as they are warrantied for life. Bottom bearings still fine
Some nice looking 5 spots there. Seems quite common to build them up with 160 forks. Are offset shock bushings a readily available part for these?
Captain M, do keep coming back to the BLT. Had a Blur XC for years now and still love it. Only real complaint is the frequent bearing maintenance. More travel, better bearings, better VPP, it is tempting. The BLT with a 160 fork is a lot more tempting than the Nomad too (which has never really done it for me.) Getting quite common on the trails now though 😉
mrblobby - I think Mountain Trax still sell the 5-spot so if you're after a demo and they haven't got one have a word and they'll most likely get hold of one for you. They're my LBS and where I bought my Five, most of the demo bikes I tested were from there and the service is great. Eg, they didn't have a Five in my size to demo so made a call to Orange and got one for me.
I'd echo the above about riding demo's as close together as you can. I got a mate to come with me and we took out two demo's at a time, riding a set route round Swinley once on each bike back to back. It's the best way to compare. Did it in a kind of knock out competition, the final was held on Whites Level.
Pastcaring, that looks like an awesome bike, id love to point that at a rock garden 🙂
mrblobby - just got an email from M-Trax, the have a 5-spot in medium on sale. It's a complete bike, componentry is OK but if you have kit to upgrade to it might be a good option if that's what you're looking for?
http://www.mountain-trax.com/product/3936/Turner_5_Spot_Custom_Bike
MBR review from 2010 best bike American classics.
Did spot that review a while ago. Notice that Rutland are also doing some good deals on them. Not sure it's the one for me though.
Float 36 on a HL Spot - yey or nay?
Thanks Khani - those rockers are thin on the ground these days tho
Crc had some 5.5 rockers a bit ago, dunno if they still have
What scienceofficer said +1, not found another as good (for me 😉 ) all-round yet,
EDIT. And what coogan said as well, fell off mine all over the place 😀
Morning, any pointers on air pressure etc for the shock?
Try 10psi lower than your weight in lbs
Ta 🙂
I must admit the 5spot looks really nice in grey/silver with black decals 8)
Hora
Start with body weight in the main air chamber. Get on the bike with all your riding gear, including water in the Camelbak, now check suspension sag. To do this, pull the little O-ring up on the shock shaft; now get off the bike gingerly as to not upset that measurement. Once off the bike, measure how much shock shaft is exposed above the O-ring. For proper setup you should measure about 30% of sag from total stroke.
Dave Turner recommends about 3 clicks in for the rebound and never use the propedal.
[url= http://www.turnerbikes.com/010/010tech.html ]Click here and then click the Proper Shock Set up tab.[/url]
