Turbo trainers - re...
[Closed] Turbo trainers - recommendations please
Looking for an entry level turbo trainer - can spend up to £160
Any recommendations to go with my road bike
Thanks very much
Posted : 17/10/2012 9:37 pm
cheapest magnetic one you can get. IME oil ones overheat and blow up messily, and wind ones are noisy.
Don't spend a lot, you shouldn't be spending long on it.
Posted : 17/10/2012 9:50 pm
[url= http://www.dcrainmaker.com/2012/10/my-2012-trainer-recommendations-early.html ]DC Rainmaker[/url] has a few ideas. May be a bit US biased.
Posted : 17/10/2012 10:17 pm
I have been very pleased with the cycleops fluid 2 I have had for a few years, although it is outside your price range. It is a well built bit of kit. In comparison the Tacx Swing I had before fell apart after a couple of years of use. Also I much prefer the resistance from the fluid trainer. Include a massive fan in your budget too!
Posted : 17/10/2012 10:23 pm
Thanks - anyone else?
 DT78
Picked up a second hand tacx satori for £100 plenty of people buy them and barely use them.
Posted : 17/10/2012 10:31 pm
It was a Cyclops Fluid 2 that spewed oil all over my hall floor 🙁 The advice about the fan is spot on.
Posted : 17/10/2012 11:10 pm
DC Rainmaker has a few ideas. May be a bit US biased.
Are either of the budget options available in the UK?
Posted : 17/10/2012 11:16 pm
Add a sweat net - I used an old towel until it fell off, into the chain, and wrecked the rear derailleur.
Posted : 18/10/2012 7:25 am
New Tacx Blue Matic or Blue Motion? Comes with software to allow you to use all their filmed HD rides to keep it interesting.
Posted : 18/10/2012 8:20 am
I've got a Minoura V150.
Picked it up in a sale from Evans and came in under your budget.
Not sure on pricing now but think RRP was slightly above that.
Anyway, it's a mag trainer with variable resistance settings and is quiet and easy to use/set-up. Not particularly fancy but does its job very well. Oh and it's adjustable for wheel size too.
Posted : 18/10/2012 8:25 am
Important thing to look for is number of levels of resistance (must be handlebar mounted), weight of flywheel, power handling capability.
Good luck!
Posted : 18/10/2012 8:32 am
