I am thinking about buying a turbo trainer and have whittled it down to two options
The Cycleops fluid 2 at £171
[url= http://www.wiggle.co.uk/p/cycle/7/CycleOps_Fluid_2_Trainer/5360019997/ ]Fluid 2[/url]
or the
Cycleops Magneto at £132
[url= http://www.wiggle.co.uk/p/cycle/7/CycleOps_Magneto_Trainer/5360019996/ ]Magneto[/url]
Also wondering if the training mat is worth buying?
Anyone had these and got an opinion on which is best?
Thanks
I have a Gist from CRC, it's better then the cycleops I had before and cheaper. It depends whether you like mag or fluid really, mag seemed to be slightly louder.
I'd get a training mat and a from wheel stop. You do tend to travel without one and get a lot of sweat on the floor.
Just get a basic one. Mine's quite old and has a fan on it that makes it harder to pedal the harder I pedal. Great for intervals.
To alter the resistance, I change gear.
A friend gave it to me.
You might want to get a towel to catch your sweat if you don't want to have to mop up a puddle every time you finish using it.
I just did a google images search on 'turbo trainer' and this appeared
[img]
[/img]
mine's a bit more basic that that.
there we go
[url] http://www.shinybikes.com/bikes/tacx-t1800-speedbraker-trainer.html [/url]
downsides - noisy as ****.
I got a Tacx one from CRC with 10 resistance levels for £125. I don't know how it compares to others, as it's the first one I've used. But it seems pretty good & gets good reviews.
Not that this helps you decide on choosing between the two above!
I use a couple of phone books to prop the front wheel up & I keep meaning to get some kind of towel thing to stop me dripping all over the bike. Might make one myself from an old towel.
PS - if you do end up getting the Tacx one, make sure you read ALL the instruction first & use the correct adaptor for the flywheel assembly. I didn't and then had to take it all apart & start again!!
Tacx Flow, Job done
Tacx Fortius, bloody expensive but you will actually use it as opposed to letting it fester in the garage.
Did 3 hours on mine climbing mountains the other week, well it was raining outside ......
Get a pedestal fan to stop you sweating so much. My local Wilkinsons is selling them at 12 quid at the moment.
Fortius = £595 or thereabouts 😆 from £132 I dont think so
The Flow looks pretty good but again I think a bit more than I want to spend.
Thanks
I've got a Tacx Satori and very happy with it.
Stable, strong & reliable (it took quite a hammering over the winter as I was too much of a pussy to venture out into the dark wet nights).
Little noisier than I would like (have to turn TV up louder) but for the price it's better than any of the others I checked out.
