Turbo Trainer begin...
[Closed] Turbo Trainer beginner question...
 cb
I have a very old and basic Elite model. Do I have to get a non-QR back wheel set up or should the QR lever fit into the turbo trainer some how. Initial look suggests that it won't fit?
THanks
Posted : 23/01/2012 3:51 pm
My back wheel with QR fits into my Elite clamp perfectly... It has a little cutout for the lever, you might have to twist the end cup around a bit to get it to fit properly.
Posted : 23/01/2012 4:01 pm
if mogrim's advice doesn't work it might be that the design of your lever won't fit (Traines usually come with there own), so just get a suitable QR off [url= http://www.wiggle.co.uk/tacx-turbo-trainer-quick-release-rear-skewer/ ]wiggle [/url]- flat ends with cam as far in as possible
Posted : 23/01/2012 4:08 pm
Apart from seven's comment, another thing to bear in mind is that when you tighten and loosen the turbo clamp you might end up loosening the QR too - always check it again before you ride.
Posted : 23/01/2012 4:12 pm
 cb
Thanks all
Posted : 23/01/2012 5:00 pm
If you're doing a lot on the turbo then it's worth getting a turbo specific tyre. Doubted it'd make much difference but I does. Feels more connected and smoother somehow.
Posted : 23/01/2012 5:05 pm
