Tubelss advice - si...
[Closed] Tubelss advice - sidewall cuts
 cp
OK, I'm new to tubeless.
I have seated the tyres on the Crest rims fine, inflated without sealant to fully seat beads, and the only place I can sense air coming out is from a small sidewall scrape, about 1cm long. There's one on each tyre. If I put sealant in, will the sealant be able to seal sidewall damage like this?
I don't want to make a mess of everything with sealant if it's not going to work without a tyre repair...
Posted : 22/06/2013 9:55 pm
Patch the tyre, the sealant won't manage that on it's own. Park tyre boot?
Posted : 22/06/2013 11:06 pm
 cp
To clarify, they are not 'cuts', more grazes. The tyre will inflate (to say 40psi) and it just sounds like a pin prick puncture in an inner tube - it deflates, but not all that quickly.
Posted : 22/06/2013 11:55 pm
Sounds like just the kind of thing the sealant is meant for; some might come out through the hole, but, under pressure, it should seal it pretty quickly.
Posted : 23/06/2013 12:13 am
 cp
kinda what I was thinking. job for after sleep now, will try in the.morning!
Posted : 23/06/2013 12:20 am
or smear with vulcanizing solution?
Posted : 23/06/2013 1:53 pm
 cp
Well, isn't tubeless a revelation! That was very very easy to do - Bontrager 29-1 mounted to Crest rims, initially with tubes to seat both beads, then remove tube from one side. push the removed bead back up a bit on the rim well, then inflate - went up easily.
Leaky sidewalls as above. Remove air, add 60ml of stans fluid, reinflate and wow - hissss.... squirt of jizz & seal. Wow, super impressed ๐Ÿ™‚
Test ride later once the chain comes out of the dishwasher ๐Ÿ™‚
Posted : 23/06/2013 3:49 pm
 cp
& lopped an estimated 300g from the wheel weight.
Posted : 23/06/2013 3:59 pm
