Tubeless with hole,...
[Closed] Tubeless with hole, repair ?
Got a Vittoria Goma tyre on the G-160, yester i got home and went to pull off a bit of stick which happened to be a big ass thorn which put a 2-3mm hole in the tyre. Simple enough location, but wouldn't seal with fluid. It's the sort of thing you'd repair on the trail with a tubeless kit insert, but at home, would you bother ? I've never actually punctured a tubeless setup in the past 5-7 years, so don't know if the normal plan is to just bin it ?
Posted : 14/12/2020 3:25 pm
No way. Stick a anchovy in there and crack on.
I've got repairs still going donkeys after fixing.
Posted : 14/12/2020 3:27 pm
Repair it, should last fine for the life of the tyre
 igm
Dynaplug, anchovy or mushroom.
First or last of those for me.
Posted : 14/12/2020 3:28 pm
I'd just stick an anchovy in it and crack on
Posted : 14/12/2020 3:32 pm
Repair it. I've a repair in my tyre that's been there a couple of years now.
Posted : 14/12/2020 3:35 pm
Yep, anchovy and crack on!
As others say, use an anchovy, failing that a bacon strip ;o)
Posted : 14/12/2020 3:37 pm
If I'm at home a mushroom plug every time. Even managed to do them where its on the edge of the rim.
Buy a pack and share with the mates is the cheapest way + can of vulcanizing glue with the brush and you will be set up for life
https://www.ebay.co.uk/itm/174431365958
https://www.ebay.co.uk/itm/Vulcanising-Cement-Tyre-Repair-Glue-With-Brush-Tyre-Patch-Car-Van-Bike-236ML/123109368500?hash=item1ca9e3e2b4:g:oHQAAOSw495dCpzo
Posted : 14/12/2020 3:38 pm
If you can't be arsed, anchovy, if you've the inclination to repair it a bit more long term, mushroom plug.
Posted : 14/12/2020 3:39 pm
I completely ignored you and gave it and another one i had for free to a mate for his boys
Posted : 14/12/2020 3:45 pm
