Tubeless Tyres for ...
[Closed] Tubeless Tyres for Road - a Tip from the Stupid/Ignorant
This is a public service announcement to save eardrums ๐Ÿ˜†
Don't naively assume that it's the same with MTB tyres, and a bit of rim-strip, a little lubrication to help seat the bead and some vigorous action with a track pump will do.
After several attempts which all resulted in the bead popping off the rim at around 80 PSI with an almighty bang ๐Ÿ˜ฏ I stopped trying and did some research. Apparently you need tyres with a special bead ๐Ÿ˜ณ
Fortunately none of these attempts had sealant in the tyre so the living-room carpet wasn't ruined ๐Ÿ˜€
Cheers, Rich
Posted : 31/07/2012 8:27 am
LOL. I'm running tubeless on my CX and had some fun getting a combo that worked without the gunshot - I had a few blowouts at 70psi with sealant though luckily not indoors...
(FWIW, the solution that worked was stans Arch Ex rims with stans tyres at 60psi)
Posted : 31/07/2012 9:07 am
I'm just glad that I discovered this before riding - having a tyre go while out and about wouldn't have been fun ๐Ÿ˜ฏ
Cheers, Rich
Posted : 31/07/2012 9:46 am
I've run some CX tyres on a ghetto setup successfully. The sidewalls were quite porous though and it took 3 or 4 inflations/deflations over a day for the sealant to properly seal it. Bit of a faff and more of an experiment than anything, but they did work.
But for road tyres, yes, you need proper tubeless tyres. More coming to market too - Hutchinson has a new lightweight one, Schwalbe have some in the pipeline, Maxxis has the expensive and elusive Padrone, etc. etc. What I want is a 28mm one for the commuter, then I'll be tubeless everywhere (except the BMX - that's next).
Posted : 31/07/2012 10:35 am
So can you run normal tyres tubeless? I have ultremo ZX on Stans alpha rims.
Or I guess the tyre will just blow off?
Posted : 31/07/2012 12:47 pm
Bonty coming out with them too - lighter versions available now I think.
25c too.
Janesyprevious threads have shownmixed experience using regular tyres. Proper tubeless ones have carbon beads to stop stretch apparently.
Posted : 31/07/2012 3:44 pm
Back in the early days of MTB tubeless (before road tubeless) a friend converted his DT RR1.1s with some electrical tape and some bog standard GP4000s, they went up and seemed fine, dunno if he still uses them, I suspect not, but he didn't die.
IME once a tyre's blown off a rim with any amount of pressure in it'll then be ripe for the bin!
Posted : 31/07/2012 3:50 pm
njee20, I hope that isn't true about tyres blowing off rims being good for the bin, otherwise I've just ruined a brand new set of Michelin Pro3's ๐Ÿ™
Will see if they withstand a decent amount of pressure with tubes and go from there...
Cheers, Rich
Posted : 02/08/2012 10:19 am
Certainly all the MTB tyres I've seen that have been blown off rims are ruined, it tends to damage the bead
Posted : 02/08/2012 10:30 am
I had a fat albert blown off at 70psi that I'm still riding on the summer bike 18 months later with no bother.
Posted : 02/08/2012 7:53 pm
Fair enough. I've got 4 ruined Schwalbes that blew off a dodgy rim! None will stay on afterwards, not even on other rims or with tubes in.
Posted : 02/08/2012 8:43 pm
