Tubeless slow leak....
[Closed] Tubeless slow leak...
In both tyres!! Only set them up last week and haven't ridden on them yet but they're going down, takes around 3 days to empty. I stuck a small 2oz bottle of stans in each. Bonty's on Crossmax. Would more sealant do it?
Posted : 03/07/2013 3:34 pm
Riding on them will probably do it, it gets the sealant in every nook and cranny.
Posted : 03/07/2013 3:37 pm
Hold the wheels horizontally (both sides) and give them a good shake seems to work for me.
I guess that just helps the sealant get into more of the nooks and further crannies.
Posted : 03/07/2013 3:42 pm
Riding... Best to set up just before a ride. Lots of different motion that get the sealen everywhere.
Posted : 03/07/2013 3:44 pm
+1 for just have a ride. I had a slow leak when i first went tubeless. Took it for a few rides and not a problem since.
Posted : 03/07/2013 3:49 pm
It might not have yet sealed.As said ride them and keep an eye on them. Sometimes the sidewalls can take a while to seal up.
If they are still going down,check the valves are seated properly,and the rim tape hasn't shifted.Finally a slug of extra sealant might do the trick.
Posted : 03/07/2013 3:54 pm
see stan's website for how to jiggle it correct then lay it flat each side. or use soapy water to find the leak and then ensure you get sealan on that area
Posted : 03/07/2013 3:57 pm
Fairly normal to leak a little until you have been for a ride.
Posted : 03/07/2013 4:59 pm
Thanks chaps ๐Ÿ˜€
Posted : 03/07/2013 5:10 pm
loddrik your tubeless is broken,do not ride it,take it back to the shop,and ask them to fix it ASAP
Posted : 03/07/2013 5:23 pm
2 things take the wheels of bike and shake about horizontal and get out riding, that usually sorts mine out!
Posted : 03/07/2013 5:31 pm
