Tubeless sealant - ...
[Closed] Tubeless sealant - anyone use an injector? (warning: bimbo content)
I'm making a right pig's ear of replacing No Tubes sealant. If I just want to top up sealant only, is an injector a bimbo-proof way of doing it?
Thank you so much!
Makes coffee and awaits pointing and laughing ๐Ÿ˜‰
Posted : 22/08/2009 2:40 pm
What's an injector?
Do you have presta valves with removable cores? Just unscrew the core and squirt some in.
Posted : 22/08/2009 2:42 pm
I've got one & find it's easier just to leave the inner part of the syringe out & use it as a screw-on funnel
Thanks for replies.
An injector is mentioned on the No Tubes website and wondered if it would be easier to use than possibly spilling it on my feet. I have the large bottle but I may well have a small funnel in my kitchen. Thanks!
Posted : 22/08/2009 2:46 pm
 pnik
I've got the stans injector and find it makes life much easier. and less messy.
Posted : 22/08/2009 2:51 pm
i keep meaning to buy a screw on injector at the min i use a baby medicine syringe but as i found the end was a bit too big i put one of the baby medicine bottle stopper things its to put in end of bottle to invert it and fill syringe without spilling.
i push it on the valve stem then inject into that . no mess that way
Posted : 22/08/2009 3:02 pm
yes, the injectors make the whole process so much easier. Just remember to remove the valve core first! ๐Ÿ˜ณ
Posted : 22/08/2009 3:12 pm
damn my computer. Another double tap
Posted : 22/08/2009 3:13 pm
I made one, piece of cake. "Borrowed" a big glass syringe from work which had a fitting on the end normally designed shockingly enough for a needle, i then found some clear plastic tubing the correct diameter to go over the stans valve (core removed of course) and heated it up/semi melted it onto the syringe at t'other end.
Works great! No leaks and cost me all of 50p to do.
Posted : 22/08/2009 3:43 pm
small plastic syringe 10cc from Boots (cheap) and cut bottom 2 inches off plastic empty water bottle. pure in and suck and squirt 2 or 3 lots in each tyre and can syringe up excess and squirt back in bottle
Posted : 22/08/2009 10:31 pm
Ive got the injector, think it makes things much easier.
Posted : 23/08/2009 11:39 am
get a small bottle of wheel milk from JRA and use that? the bottle i mean, not the milk if that's not your sealant of choice!
works well for me.
Posted : 23/08/2009 11:55 am
I use a 50ml syringe off ebay. Slots straight in.
Posted : 23/08/2009 12:09 pm
 devs
Don't you get a screw on "injector" with the bottle? I'm sure I did. Don't use it though, I use a 200ml Joes bottle to measure and squirt it in. Simple.
Posted : 23/08/2009 12:11 pm
