Tubeless help - lea...
[Closed] Tubeless help - leaking around valve
Why is it suddenly leaking around the valve? It wasn't before.
DT wheel, Stan's tape, DT valve.
I've put a rubber washer under the nut on the valve which has enabled it to seal now, but surely no air should be getting through the tape????
Posted : 30/12/2013 10:30 pm
I've had this in the past, was nothing to do with the valve. The tape was leaking, tear from a tight tyre fitting, and sealant was escaping from the valve hole. Presume path of least resistance.
Posted : 30/12/2013 10:49 pm
put a double thickness of electrical tape round the rim.
Posted : 30/12/2013 10:51 pm
valve/tape interface is the weakest link
how old is the installation?
... for 100% reliability, re tape it
Posted : 30/12/2013 11:03 pm
What rsvktm said, your tape has probably split somewhere on a spoke hole burr or something.
Posted : 31/12/2013 12:37 am
Whatever you do, don't be tempted to tighten the external nut too much-I managed to pull a valve into the rim section doing that
Posted : 31/12/2013 12:44 am
Thanks. I've opened it up and the tape is fine but the valve has rotated 90 degrees and that is probably the problem (DT valves don't have a round rubber bit on the inside like Stan's valves but kind of go along the line of the rim, so if they aren't in line there could be a gap). Still at a loss as to why it happened 2 hours into a ride though!
Posted : 31/12/2013 10:18 pm
