Trying to salvage a...
[Closed] Trying to salvage a seized xD cassette
I've got an 1175 xD cassette which is well and truly seized onto a pro4 freehub. The splines are buggered. It's still got some life in it, so it would be nice to salvage 1 of the two things if I can.
Is there a (probably destructive) way I can rescue at least 1 of these things? I haven't looked at an xD freehub in years so I can't visualize how they go together.
Posted : 13/05/2021 7:48 pm
Is the inner ring unscrewing at all ?
Are you talking about the splines the cassette tool plugs into ? If so, would a different cassette tool help ?
Posted : 13/05/2021 7:54 pm
Nothing is moving in the slightest unfortunately.
The splines are, in fact, now basically all at an angle! Can't get a tool in 🙁 will try and get a photo.
If i cut what would be the locking on an hg cassette, will that write off the cassette?
Posted : 13/05/2021 8:20 pm
Did you remove the drive side hub end cap before you tried to remove the cassette?
Posted : 14/05/2021 6:42 am
Yup, got the cassette tool in as far as it would go. Had a breaker bar on the cassette tool! It didn't come out of the splines until an awful lot of force was put on it.
Posted : 14/05/2021 6:46 am
It shouldn’t come out at all, mine doesn’t even with me standing on it - how far in does the tool go - it should be at least a centimetre?
Posted : 14/05/2021 7:29 am
Have you got the freehub off and can work from the 'back'?
Which is more important, saving the cassette or the freehub?
Posted : 14/05/2021 7:41 am
Sounds like the cassette is dead if the splines are gone.
Probably need to replace both ☹️ ?
I slather the freehub body with assembly paste and it is generally ok.
Posted : 14/05/2021 7:58 am
 dlr
My last xd cassette was siezed on, only way I got it to budge was to use a bench vice with the cassette tool in that, chain whip attached and clamped round spokes with my hand then turned the wheel itself which gave a lot more leverage and one massive crack and it came undone
Posted : 14/05/2021 8:14 am
 dlr
ah mine was just I couldn't unscrew it, if yours is stuck on as it's cut into the splines then not sure! Swear a lot? Sometimes works for me
Posted : 14/05/2021 8:15 am
