Truvativ GXP crank ...
[Closed] Truvativ GXP crank creaking problem
 mrl
I have a basic outboard bearing GXP crank that has a constant creak from the non driveside. The bearings are fine and have no problems. I have tried seating the crank arm on the spline with grease and without grease but nothing seems to help. It just keeps creaking on every pedal stroke! Has anyone found a solution?
Posted : 01/09/2010 1:27 pm
Checked the pedal threads?
Posted : 01/09/2010 1:32 pm
 mrl
Yep, all clean and greased.
Posted : 01/09/2010 1:57 pm
You don't mention removing, cleaning and regreasing the BB cup? thats usually my first port of call for removing creaks.
Posted : 01/09/2010 2:04 pm
Try a squirt of WD40 after fitting it and tightening everything up. Worked for me, though not sure why as I thought I'd greased every available surface...
Posted : 01/09/2010 2:08 pm
spraying gt85 or wd40 as suggested [url= http://www.singletrackworld.com/forum/topic/truvativ-gxp-bb-adjustment-help ]here[/url] worked for me (cheers hooter!)
