Does anyone know where I can get hold of a TRP Spyre barrel adjuster? Google suggests this place but they are showing as on back order (and also quite pricey!). Any ideas?
https://outlet.upgradebikes.co.uk/Outlet/TRP/TRP-Range/TRP-spares/TRP-Barrel-Adjuster-for-Spyre
Sorry cant help but I need a cable boot for a Spyre and not having any luck finding one.
I'll let you know if I find an adjuster.
Can you not just use any old M6 brake cable adjuster?ย It's not in a particularly awkward spot on the TRPs, e.g. this one from amazon?
edit: that one might be M5 rather than M6 but just type M6 brake cable adjuster into amazon and some others come up
I swapped mine for nice alloy ones from eBay. Cheap and easily available.
i think they were m6
Try hereย http://www.cyclerepairman.co.uk/Brake-System-Parts/Brake-Spares/C18-184-1-0.htm
they are M6 type at the bottom.
Think he has my cable boots as well.
Thanks all, will check them out. Wasn't sure if I could just swap it for a random one. I did try using on off some Tektro Lyra calipers I have in the spares box but it appears to be the wrong size. Will continue to have a look and might pop into the lbs round the corner from work tomorrow and see if they have anything laying around.
Mariner, I'm also missing a boot, was just going to run it without it
