Trouble with my fro...
[Closed] Trouble with my front derailleur
[#11252202]
Hi all,
1st post.
I am having alot of trouble with my 3 gear front derailleur - it has never really worked right. It refuses to shift to the lowest gear no matter how much I play with the limits/stops screws.
I can sometimes rarely get it go down, when I am at speed and shift from the highest to lowest in one go. My bikes ride are in pretty hilly country - so needless to say, not having easy access to that lowest gear is driving me mad. I have taken off, cleaned it, oiled etc - nothing worked.
Any help, is much appreciated.
Ray K
Posted : 16/06/2020 6:39 pm
Is it the original one that came with the bike.might just need rotating slightly on the frame for better chain contact.
Posted : 16/06/2020 6:42 pm
Does it move OK with the cable disconnected? Does the cable run freely when disconnected? Is the derailleur mounted correctly, e.g.correct height above chainrings?
Posted : 16/06/2020 6:55 pm
Follow this Park tutorial, if you take it step by step it'll work (ignore the deadpan delivery!)
Park Tools
Posted : 16/06/2020 8:03 pm
So I took a much closer look yesterday, I found a number breaks or tears in the middle gear. I don't know how these happened, but could these be the culprit.
Second gear wheel.
Posted : 19/06/2020 12:43 pm
