Sheared Pivot Bolt ...
[Closed] Sheared Pivot Bolt in Carbon Frame
[#11252200]
I'm a complete muppet.
My pivot bolts have two different torque settings depending on which bolt it is. I forgot to change the torque setting on my wrench when moving from one bolt to another and snap. I sheared off the bolt head and about 5mm of thread. Deeply embarrassing and quite sickening at the same time.
How easy is this going to be for a competent bike shop to sort out?
Posted : 16/06/2020 6:38 pm
Easy with no head on it theres no friction so should wind out with pliers or fingers
Posted : 16/06/2020 6:57 pm
Depends on the bolt/location/frame etc.
A picture would help.
Posted : 16/06/2020 7:20 pm
Cant do pictures on here, but its one of the two bottom pivot bolts on a Hightower 1. The one on the swingarm / chainstay just by the bottom bracket.
Posted : 17/06/2020 9:54 am
These ones?
Posted : 17/06/2020 11:00 am
Nice one. Yes. The one to the bottom / right on that pic. Its the sliver bolt thats snapped a bit along its length due to my stupidity.
Posted : 17/06/2020 11:04 am
I'd imagine that you#d be able to get something grippy onto it (rubber on the end of a pencil?) and it'll turn easily. With no head on it there's no tension on the bolt.
Unless there's threadlock to overcome. Then you might need something else.
Posted : 17/06/2020 11:05 am
pop i to the lbs.
or easy out drill bit.
Posted : 17/06/2020 11:12 am
If you've snapped one of the silver bolts that holds the expanding collets in place, it shouldn't be so bad. First get the expanding wedge out (these can be a faff at the best of times, but should come out eventually. If you can get a large hex key onto the axle, then remove and sort (or even replace - they're not expensive) on the bench. If you can't, you may still be able to unscrew it as the axles themselves shouldn't be much more than finger tight anyway. Use a regular, tapered wood screw on the hollow opposite end of the axle and it should screw straight out.
Once it's on the bench you can have a go at removing the snapped portion of the bolt, but the axles are an effective consumable anyway, so easily sourced for a few quid.
Posted : 17/06/2020 11:35 am
Phew. Thanks for the reassurance.
Posted : 17/06/2020 11:57 am
