Tripster ATR finall...
Tripster ATR finally built up - lush!
57cm Tripster on ebay if anyone's interested http://www.ebay.co.uk/itm/Kinesis-Tripster-ATR-Disc-57cm-/291235727059?pt=UK_Bikes_GL&hash=item43cf0086d3
Posted : 04/09/2014 8:56 pm
Jesus Somafunk, can't imagine how they'll ride but those Jones bars look lovely on your Tripster!
Took my compact off today and went back to 1 x 10, 40 tooth Surly ring and 11-36 at the back. Absolute relief and though I don't understand why faster over the same loops. Supposing it's because of better cadence, not losing momentum on shifting etc,? Certainly notice that I don't tend to shift as much as I did with a front mech.
Think it's time this thread had it's own website!
Posted : 04/09/2014 9:23 pm
I wish I hadn't clicked on that eBay link now...
Posted : 04/09/2014 9:33 pm
Luckily its too big for me
Posted : 05/09/2014 8:00 am
Not found this yet on the thread, what size disc are people using?
I reckon with a bit of compromise on the groupset and a rebuild on some old hubs I can make this happen ...
EDIT: Just had a thought - DT240 hubs, would they likely take 11 speed (there's a tempting offer on Merlin)? Or stick with 10? Or is that a cog too far and I should just go but the Kinesis CX wheelset from somewhere?
Posted : 05/09/2014 9:32 am
Answered my own question it appears not - specific freehub for 11 speed, so not backward compatible with 10. Might stick with 10 now, don't think I gain much from 11 anyway apart from it being one louder 🙂
Posted : 05/09/2014 9:52 am
160 discs, the rear is a post mount 160 so you cant go smaller.
Posted : 05/09/2014 10:57 am
@TLR:
Thomson post here. I had dreadful slippage as it's a clear mis-match in size. Rather than torquing up the clamp so that it pinches the post only at one point, I used a beer can shim and it fits like a glove. Minimum torque required on the seatpost clamp to keep it nice and secure (even greased up), with minimum stress on teh seat tube.
Posted : 05/09/2014 11:56 am
which beer ?
some more beer can tips here :
http://velonews.competitor.com/2002/12/bikes-and-tech/making-it-work-have-a-beer-fix-your-bike_3288
Posted : 05/09/2014 12:58 pm
That's a very good question Turnerguy. I started off with a 440ml can of Becks which worked fine, but on further reflection I decided I wanted a "full sleeve". i.e I wanted all of the insterted post to be fitting nice and snug with the frame along its full length so that there wasn't any undue waggling or stresses. I therefore upgraded to a pint can of Stella which had the height for the job.
It's a wee bit tricky to get the top of the can level with the top of the seat-tube (or a mm above it, which is hidden by the collar), especially when the parts are greased and you've had a few tinnies, but once it's done it's done.
Posted : 05/09/2014 2:24 pm
what sort of weight do these come in at in off-road sort of mode ie with chunky tyres?
Posted : 05/09/2014 3:15 pm
[i]Not found this yet on the thread, what size disc are people using? [/i]
I'm using 160mm front/rear.
[i]what sort of weight do these come in at in off-road sort of mode ie with chunky tyres? [/i]
Mine is/was 9.1Kg with my 40mm clement tyres, you'd be hard pushed to get the weight much lower but to be honest the weight of it is immaterial compared to how well it rides/glides on and off road.
Just off the phone to middleburn regarding the suitability of fitting the RS8 cranks to my Tripster and they are about to release a super compact double road/cx version 30 tooth inner/40+tooth outer which will be ideal for touring and ideal for my Tripster, so it's now a waiting game till they are released and i can get my bike built back up……I'm not very good at waiting though……..
Posted : 05/09/2014 3:31 pm
that seems pretty light - is that with pedals out of interest?
will those clement tyres work tubeless?
cheers
Posted : 05/09/2014 4:08 pm
Yeah, pedals included (xtr spds), why would you weigh your bike without them?. I didn't think it was particularly light - is 20lb considered light?.
The clement tyres may work tubeless with a slightly larger rim dia than the Kinesis CX disc V3 rim which i believe is made by WTB to a Kinesis design, the Clement tyres are too baggy/loose on the Kinesis rim.
Posted : 05/09/2014 7:45 pm
i think so - my salsa vaya (steel frame and fork) is 28. 😯
The fat bugger [u]will [/u]be going on a diet though.
Posted : 05/09/2014 8:01 pm
28lbs!, are you sure?, my mtb with a dropper post weighs less than 24lbs, at the moment with a carbon fork it weighs 21lbs…………your vaya must be built for [i]comfort[/i] rather than [i]speed[/i] 😉
Posted : 05/09/2014 8:08 pm
I think mine got under 18lbs with Ultegra 6700, Spyres, Ritchey WCS carbon contact points, the latest CX Discs, 25c Conti folding tyres, no guards... Back in the real world now with 37mm tyres and SKS Bluemels on, I'm confident it's still a bit under 20lbs with pedals and all the other stuff on it (mirror, bottle cages, garmin mount, pump, seatpack bracket...)
Talking of which - does anyone want a set of [b]SKS Chromoplastic P35 mudguards[/b] in black? They're suitable for up to 28mm tyres and have been cut to fit a 54cm Tripster so would just need a couple of short extending brackets for the rear stays. I've put the Bluemels on now and am happy sticking with the wider tyres so don't need these narrow ones. It could save someone hours of pain and suffering with the measure/fit fun and games you get for free with every pair of SKS guards if they'll be of use. 🙂
Posted : 05/09/2014 9:33 pm
Mine was 19lbs dead with the standard kinesis build kit and shimano DH spds....... 8)
It's now got 28c four seasons, and one Spyre SLC on the rear.
Soon to have 50mm wide bluemels and tubus airy Ti rack to cover all eventualities :mrgreen:
Another road sportive for it on Sunday, 110km Tour de Broads will be the furthest I've taken it so far.
Posted : 05/09/2014 9:58 pm
I just got the Airy Ti rack
[url= https://farm6.staticflickr.com/5563/14899589979_1b97983d51_z.jp g" target="_blank">https://farm6.staticflickr.com/5563/14899589979_1b97983d51_z.jp g"/> [/img][/url]
[url= https://flic.kr/p/oGCi1p ]DSC03265[/url] by [url= https://www.flickr.com/people/52769476@N00/ ]South Downs MTB Skills[/url], on Flickr
Posted : 05/09/2014 10:02 pm
Looks good !!
Are they small block eights too ?
What are they like on it ?
They seem like a sensible allround choice
Posted : 05/09/2014 10:10 pm
So that's three of us on here with the Tubus Airy Ti rack 😀 , the Ortlieb front roller panniers work especially well with the Airy rack btw.
You can use a single rack stay to the threaded mount underneath the top wishbone seat stay if you put a bend in one of the stays and fit it central behind the Tubus name plaque on the rack.
Posted : 05/09/2014 10:12 pm
My build kit consisted of the following,
Lynskey Ti seat post, Fzik Kium Aliante saddle.
Kinesis V3 CX wheel set with either Clement X'plor MSO 40mm gravel tyres or Clement Strada LGG 28mm slicks & continental tubes & Pauls 25th yr Anniversary wheel skewers.
Ultegra CX 70 crankset & BB, Ultegra short cage rear mech, Ultegra front mech, Ultegra 11-28 cassette, Sram chain, Ultegra shifters/sti units. XTR spds
Thomson X4 stem, Salsa Woodchipper bars, Lizard skins dsp bar tape.
TRP Carbon Spyre brakes, XT 160mm rotors with alloy spider, Yokozuna reaction brake/gear cable set.
All bolts that possibly could be were replaced for Ti on the bike.
That's all a mute point now after trashing my entire drivetrain, it's currently lying on the chair behind me stripped back to bare frame waiting on middleburn to release their new crankset of which will be included in a new XTR build with the Jones loop bars as previous page, it should be a better set-up for possible touring duties and if i don't like it then it'll do for my Soulcraft build instead.
Posted : 05/09/2014 10:29 pm
That Tubus rack does look very neat indeed.
Seeing your build list, somafunk, and not that you need them, but have you spotted on grit.cx the news (and pics) of the Pauls calipers....? 😈
Posted : 05/09/2014 10:37 pm
away for a look now…….
Posted : 05/09/2014 10:43 pm
…..I'm back
God damn!…..I've just this week bought a set of Spyres to fit an Alloy Tripster that i got for my brother at the weekend, I could have fitted my Spyres and saved myself £130…ho-hum.
Those Paul callipers look pretty nice, and seeing as i plan to fit Paul Love Levers to my Jones bars it would make mechanical sense to use them…( [i]common sense mode engaged[/i] ) but i don't need them really?….do i?….
To take my mind off the Pauls brakes…….
…….Here's a gratuitous shot of my bro's new bike that we collected last Sunday, needless to say i stripped it back to a bare frame, polish and waxed then rebuilt it with a new chain, cassette, hope jockey wheels, my old Ultegra crankset & BB from my Tripster, unused Xona front mech from original Tripster build kit, TRP Spyres/xt rotors and Yokozuma brake/gear cable set and new bar tape/bottle and cage..so i've now got a box full of old spares that may get thrown at a hack frame for winter abuse back and forward to work.
Should do him through the winter, he's never had a road/do it all bike before so he's pretty chuffed with it,
Posted : 05/09/2014 11:06 pm
Yes... Sorry about that 🙂 I just felt duty bound, knowing you'd got the levers and QRs... It's only bits of metal...
Anyway - the alloy Tripster looks good. I had one in the blue and liked it a lot. It did me proud and paved the way for the ti one. It's a different geometry to the ATR of course, but still works very well.
Posted : 05/09/2014 11:15 pm
Gonetothehills, I'd be interested in the mudguards,I'm having a 54cm built up atm & will be running 28mm tyres to get me started.How much do you want for them?
Posted : 05/09/2014 11:31 pm
Phew!….. I had a closer look on Pauls Facebook page and i see the calliper has one moving piston and one fixed so i can rule them out 🙁 .
I meant to add i've also managed to buy a set of the [url= https://www.ridepdw.com/goods/fenders/full-metal-fenders-city ]full metal city fenders from PDW, [/url] from a rough offer-up fit with wheels in the frame it seems they will clear the 40mm MSO tyres so i'm happy with that purchase, and they do look pretty damn good, or at least as good as mudguards can ever look.
Did i just say [i]Mudguards look good[/i]?…..should i start to browse the sunday supplements for slippers and bogof deals on grey elastic waisted slacks?.
Posted : 05/09/2014 11:46 pm
Overthehill50 - great stuff! Not much at all. Drop me a line - I'm sure we can sort something.
Somafunk - that's crazy (the calipers, not the pipe and slippers). The BB5 is so flawed in that sense so to use that as a model seems strange. The Spyres are the business. I really like the look of the carbon guards that the guys at Swarf were showing and the matte ano finish on those PDW ones looks grand too. How long to wait for your cranks before the rebuild...?
Posted : 06/09/2014 7:09 am
gonetothehills - I've sent an email to your gmail so hopefully you get it & then let me know details for paying for the mudguards. Just need the bike to fit them to now !
Posted : 06/09/2014 12:39 pm
@cr500dom - no they're not small block 8's, they are Conti CX kings in 42mm width. Reasonably fast on the road, but a decent volume for off road, which is the bulk of my miles.
@somafunk - my lbs is getting some ortleib bags in soon, so I'm waiting to see what they are like.
I'm ordering the Exposure lights Revo next week for it
Posted : 06/09/2014 4:10 pm
I know it looks funny but flawless round Stanmer on 1 x 10 and still no chain drop!
[url= https://farm4.staticflickr.com/3838/15157639155_29fda9869b_z.jp g" target="_blank">https://farm4.staticflickr.com/3838/15157639155_29fda9869b_z.jp g"/> [/img][/url][url= https://flic.kr/p/p6qS38 ]20140906_111256[/url] by [url= https://www.flickr.com/people/36574813@N06/ ]Birdage[/url], on Flickr
Posted : 06/09/2014 5:29 pm
cut some pepsi max can 1" x 2.5" and fitted in the seat tube.
seems solid and reluctant to slip, time will tell...
Posted : 06/09/2014 5:52 pm
I knew there was something that looked wrong about that bike, and now I see it. Toe clips!
Posted : 07/09/2014 12:20 am
Toe clips on a Tripster?, dunno if I should be disappointed or rejoicing in the owners eccentricity .... I'm confused ?
Posted : 07/09/2014 1:03 am
[url= http://www.kinesisbikes.co.uk/atr-love/ ]hands up who got their quote linked!![/url]
Me!!
Posted : 07/09/2014 9:43 am
Me!!
corporate shill.
Posted : 07/09/2014 10:48 am
Quoted [b]and[/b] used my pic of Maureen the cow! *swoon*
Posted : 07/09/2014 10:59 am
Yeah I know, I'm confused. Tried clipless but I've got cartilage and cruciate damage and clipless just aggravates it. Works for me.
Posted : 07/09/2014 6:40 pm
Slightly OT but I notice several people on this thread are using the kinesis crosslight wheelset. I’ve been looking for a set (the new ones) but everywhere seems to have sold out. Anyone care to divulge any shops that still have stock (preferably of the bargaintastic variety)?
Posted : 08/09/2014 12:52 pm
Pulled the trigger on the frame .. now for the groupset & wheels 😀
Posted : 08/09/2014 2:51 pm
Frame on order now planning rest of build. Having seen Somafunk disaster I am looking at clutch mech setup. Already have a set of Ultegra STOI levers but wondering if I could mix this up a bit. Would Ultegra 6800 STI levers (10 speed) work with XTR cranks mech and sprocket (10speed)?
Posted : 08/09/2014 7:12 pm
Christian Fairclough on a shoot for Morvelo, now is that a Tripster?
Posted : 09/09/2014 11:58 am
You'd need a 9 speed mtb mech with 10 speed STIs. Got that set-up with road cranks.
Posted : 09/09/2014 12:36 pm
Struggling to find any too. At the moment (as I'm hoping to have duplicate hubs in two wheelsets, one for all road one light and delicate for road) I'm looking at Superstar, as they do some cheapish builds around their Tesla hubs, including a cx set on Alex rims for around £250. Hope Hoops probably another option. I have some DT240 hubs I could get rebuilt, but might get pricy when I want the second wheelset.
Maybe be ordering the group from Germany, as no one seems to have stock of a matching set in 105 (or lower).
Posted : 09/09/2014 1:35 pm
Page 19 / 61
