Triple STI on a dou...
[Closed] Triple STI on a double chainset
Will a Shimano 10sp tiagra front triple sti unit work on an ultegra 10sp double chainset? Will i need a different mech?
Also, will an 11sp chain run on Ultegra 10sp chain rings?
Thanks
Posted : 10/02/2017 10:37 am
Yes.
No, just set the stops correctly.
Probably, might wear a little quicker than it otherwise would.
Posted : 10/02/2017 10:39 am
Ace, thank you!
Posted : 10/02/2017 10:53 am
 cp
As above just set the stops on the mech correctly and use the first two positions on the sti - you'll never get to the third click.
A few years ago, 105 5600 era, quite a few bikes came set like this as stock - triple shifter with double cranks.
Posted : 10/02/2017 11:00 am
On the winter bike I've got a 105 triple shifter on a Sora triple front mech with 105 double chainste, it's all fine, just a 'dead shift', ie last click of the lever it moves but nothing happens
On the posher bike I've got a Tiagra triple shifter with a DA double front mech and double DA cranks, same things, it's all fine apart from the dead shift.
No idea about the chain, but a 10sp one seems fine on 9sp rings if that helps
Posted : 10/02/2017 2:43 pm
yes you just have a dead click as the front mech controls how far it can travel
Posted : 10/02/2017 2:44 pm
Thanks all...thats great
Posted : 10/02/2017 4:19 pm
