Hi guys,
Just asking really if anyone has/had a set of these forks who can offer me some set up figures for them. Obviously i will work out the best set-up for myself after time but i need a place to start from. I read that the Marz' settings are really crap so looking for rider experienced set-up's please.
I am ~14st with kit they are gonna be at 160mm on a DH hardtail Orange Sub Zero (1.5'' model) so stack is super low. Riding mostly local rooty woods and some drops/gaps approx 6ft drop at the most (generally).
Any tips appreciated!
Cheers,
Jay
I have these, well they are on the new build, haven't used them yet. In the Manual there is a guide to setting them up, aswell as pressures. Set it to the recommended pressure, then[i] tweek. Remember you need a low pressure shock pump ๐
EDIT: From the manual, for 80-65kg:
Positive air - 42-52 PSI
Negative air - 73 - 217 PSI
PAR air pressure - 0-30 PSI
Preload pressure - 0 - 15 PSI
Actually, just noticed that doesn't help much. But set them in the middle of those pressures, and then adjust to suit.
