Has anyone come across a company making a regular shock DU eyelet to replace the thru shaft end of a re:aktiv Rockshox shock?
I want to turn right into left.
People make mount hardware solutions the other way, but I appreciate this would be more than adapters.
No idea if its functionally feasible though.
Posted : 04/04/2021 8:56 pm
You can't because that's where the thru shaft (5) comes out of the base of the shock
Posted : 04/04/2021 9:12 pm
The only way I can see to do it would be to basically offset the shock at an angle so you the thru-body action isn't affected. (ie put your new eyelet on one of the existing "legs".
How about using a non-thru reactiv shock from an older model?
Posted : 04/04/2021 11:58 pm
