I would be interested on views regarding sizing for a Trek Remedy and what size others ride.
At 6' tall It would appear I am in between two sizes
19:5 Virtual 18:5 Actual
18:5 Virtual 17:5 Actual
I have tried both and they both feel ok.
185cm here & 18.5 virtual was spot on!!
I had the same issue between the 18.5 and the 17.5. I went for the slightly smaller size because I felt it would be more fun to throw around.
5'11" and went for the 17. I like small bike tho.
the 19.5 one esp if using 50mm stem...they come up small...see original launch thing that Matt Letch wrote + speaking from experience (previous remedy 9 owner)
atmo of course
I'm 5ft 11 ride a 19.5 virtual with a 50mm stem fits me fine and is super comfy on longer rides
Thanks for replies looks like both sizes suit different riders and views
6' on the nose, tried a 17.5" actual and it felt weeny. Now on a Medium Pitch funnily enough..
best to try first...they are pretty short and standard stems are too long to be useful
Having had one i would have to say 19.5" is the right size for someone your size.
Trek quote a 24" vtt for that size however mine measured closer to 23.5" which meant I had to run a long stem to be comfortable. Not sure where Trek get there measurements from but theirs were a mile out.
Work out what VTT you have now and match it to the remedy.
I'd always go long bike/short stem if possible.
same experience as geordiepaul...measured up shorter than figures given in Trek literature ๐
long bike + short stem IS way better than a setup where tt is too short and stem too long...as soon as you stand up your weight is too far over the front and it rides poorly.
As for a small bike is chuckable...don't get me started on that one! ๐
I'm 5"10 and went for the 17.5
fantastic suspension BTW
I'm 6'1" on a 19.5 and it feels short, the 50mm stem has now gone up to 60mm.
I was about to replace the 19.5" I had for the biggest one 21" I think it is...but didn't, dislocated my choulder instead...
6'1" btw with 34" inside leg...used a 50mm stem with 750mm wide bars.
