Trek Fuel Ex 1x9 Se...
[Closed] Trek Fuel Ex 1x9 Setups.....
........specifically what chain guide are you using given the press fit bottom bracket and lack of ISCG mounts (mines a 2010 model).
Also, bash guard, really necessary?
Cheers if you can be bothererd.
Posted : 28/06/2013 1:39 pm
Anyone from the evening crowd?
Posted : 28/06/2013 11:03 pm
Nobody rides Trek here. Sorry ๐Ÿ™„
Posted : 28/06/2013 11:29 pm
I have a 2010 EX8. I'm running it 2x9 with a Hope bash guard, Suppose you don't have to fit one but I find it useful for rocky trails in the Peaks. I believe you can get a top guide to mount same as a front mech. Also look at the Bionicon C guide, but you might not need it if have a top guide & you shorten your chain.
Posted : 29/06/2013 12:25 am
I knew there was another trek rider!!!!! ๐Ÿ˜†
Will have a look, not heard of the bionicon.
Posted : 29/06/2013 9:59 am
I've got a Top Fuel with an E.13 XCX high mount guide.
Posted : 29/06/2013 10:19 am
I used a Radium inner chain guide, worked really well and looked cool too!
Posted : 29/06/2013 10:07 pm
Wolfie - don't you ride a giant with a trek fork?! ๐Ÿ˜€
Don't run 1x9, but 2x10 with bionicon c guide and its a clever little thing with minimal noise too.
Posted : 30/06/2013 7:44 am
Raidium works well, but you need a bash guard to be the other side of the sandwich. Only for 32 tooth if memory serves, but that's plenty for most.
http://www.raidiumchainguide.co.uk/
Other - more expensive - alternative would be bash guard and a seat tube mounted guide like Hope.
http://www.chainreactioncycles.com/Models.aspx?ModelID=90477
Posted : 30/06/2013 8:22 am
Got an XT triple at the moment and never come off the middle chain ring, so want to try and give the 1x9 a go. Will check out the other stuff.
Cheers chaps. ๐Ÿ™‚
Posted : 30/06/2013 5:17 pm
