[Closed] Travel adjust on new talas forks - does it get easier?
my new talas forks are 2-3 rides oldish. The travel adjust works great when increasing travel but seems reluctant to stop at 120mm - 100mm i fine as is 140 but the 120mm setting does barely anything.
Seems like i need to go 140-100 and then up to 120mm
is this normal?
anyone?
Give them a few more rides to bed in, if you are running close to 50psi or under they can be a bit funny.
If still playing up send back to Mojo for warranty inspection, unless they're O.E bargins!
they are not oe
No warranty issues there then, give them another ride or two and see how they go ๐
Sounds like they may not be setup properly. They should stop some where mid point on the 120mm setting. As above if they don't sort in a ride or two get them to MOJO (or better still get the shop you bought them from to deal with MOJO).
