What do you all think & if you ride one any pics ?
I couldn't see any difference from the 2011 in the picture I saw. Is there any?
no difference to geometry, but rear has bolt through back end.
im selling my 2011 white one for a 2012 blue one, should come in a week or so.
142x15mm back end the new ones
[img] http://www.rotorburn.com/forums/attachment.php?attachmentid=226948&d=1329987059 [/img]
My 2012 Covert - changes from 2011 are: rear axle is now 142x12 (135x10 is optional), Kashima fox float rear shock and nicer graphics (IMO).
Coming off an intense Tracer VP, really love the Covert!!! It's
fun to ride and plenty capable.
Wheels are Industry Nine Enduro, full XO, RaceFace Turbine Stem 60mm and Answer ProTapper AM Carbon bar 720mm. Just added Rockshox reverb as well.
Currently trying to decide between the Covert and the Bottle rocket, I suspect the Covert will be better for the riding I do, but just love how the BR looks.... want badly.
jedi has a BR he loves it. And the BR.
yeah but if I buy a BR and then go to get Jedi'd I'll look like I'm stalking him 😉 Raw IS the only nice colour IMO.
@passtherizla - well if you do by the BR and go to Jedi you will be able to definitively answer the "is it the bike or the rider" question !
Ha Ha... I think that is a foregone conclusion in this case.
Can you build a more freeride balanced covert 36mm stantions etc... that could still be ridden fairly easily at trail centres etc...?
I have a 2012 one (and also a 2011 frame for sale).
For my style of riding its brilliant. You can ride up hills and plummet down them. You can ride XC and then turn up at Chicksands and have fun. You can enter it in the Bristol Bike fest and have fun, then go to the Alps for a week and not need to hire a DH bike.
Also the later frames have cable routing for uppydowny seat posts.
seems that you are doing what I would like to do with one...
Other than my dh bike the covert is now my only MTB, gets ridden everywhere.
van 36
avid elixirs 160mm f n r
gravity gap cranks, bash, stinger
xo shifters n mech
halo freedom disc wheels
reverb
36lbs.
Very capable bike and fine for xc, trail centres and light DH. I have a 2011 and just put a 10mm bolt through rear on - seems a bit stiffer.
I got mine from 18 bikes who were very helpful - get one, you wont be disappointed!
The write up in Singletrack was pretty spot on actually.
If you only want one bike and enjoy XC, trail centers, jumps, drops and general messing about as well as trips to the Alps its pretty perfect.
If your 95kg or more you may find the shock needs tweaking if your into jumps and stuff like that. Ive just got a CCDB for mine which should be fitted soon. XC its fine, but for big stuff I had to pump it up a lot and it lost its ability to rebound properly.
no, no more than about 85 Kg here... Hmmm, might see bout selling the meta.
It'd have to get the CCDB or DSP dueller treatment.
Yeah as above - I'm going to get some volume spacers for my rp23 as the high volume can isn't good for my weight!
Yeah same here, I got a smaller volume air can and its brilliant now. Talk to Mojo about rp23, v helpful on the phone and discussed the cheapest ways to make a difference.
I just rang Loco and will be getting some volume spacers for mine - seems like the simplest of solutions.
yeah they didnt have them when I did mine, its a recent thing.
passtherizla Covert is the way to go the BR is a bit too hefty. There are a couple of new Coverts on ebay for about £1100 at the moment.
If you want to replace the meta but use 160mm forks it would be best to get that with some form of travel adjust for the climbs. I use mine all the time.
Yes, spacers should do the trick. I only went for the CCDB + Ti spring option as it was paid for by my company. I probably wouldnt have done that if it had been my own money.
If anyone wants to buy my old frame its going to be for sale soon as I can swop over shocks.
I have Fox Talas on mine, a while ago we had a hill climbing challange session. My bike out climbed everyone elses. Everyone else was on a wide range of XC type bikes.
Being able to drop the travel for the steepest climbs made the difference. By steep I mean daft steep where only granny will do.
Cheers Andy, I think I'm sold on the covert, Got a few bits and pieces to sell that should bring in some money, Does anyone off hand know the metric i2i and stroke of the Covert... I have a 200x51 RP2 that I could use in the mean time if it will fit?
nope 190x50.
ta.
does the travel come from the linkages rather than the shock? just interested as I've never thought about it before this will only be my secodn full susser
It comes from both. You'll notice something called 'leverage ratio' being thrown about which relates to how much the suspension linkage compresses the shock stroke (exposed part of the shock).
For what it's worth I have a Covert. Used to ride a 2007 Enduro SL which was great, but the Covert is a lot stiffer, easier to pump and jump and climbs better.
The length of the linkage dictates the travel to shock movement ratio and then the length of the shock stroke dictates the travel.
EDIT: If you use a longer shock body than the frame is designed for ie 200 instead of 190 then the bike will be jacked up with steeper angles. Well that is unless the frame doesn't top out first. Your travel will still be the same as both the shocks mentioned above are 50/51mm stroke.
thanks gents. 🙂
The covert has a leverage ratio of 3:1, so for a 2 inch shock you get 6 inches of travel.
Its quite an agressive ratio which is why not all shocks cope. Ive just got a CCDB for mine and got Stendtec to change the shim stack and oil weight to suit it.
i got the bottlerocket as the weight difference is minimal but the back end is hench compared to the covert. 5 and 6 in ch adjustable too.
with my reverb it rides the nuts! 🙂
I was in Pedals in Edinburgh last night and they are offering a 10% discount on all Transitions as an opening offer.... if that helps
http://www.pedals-edinburgh.com/
Sorry Jedi - despite doing a day with you I cant seem to recall what "hench" means 🙂
Can you translate that for me. Cheers.
Dont buy a new one, buy my frame and shock and fit your own bits too it. (shameless plug, sorry)
hench = burly = bigger 🙂
