Training tips
[Closed] Training tips
[#8113934]
I ride 2x a week, one ride is a 2 hour week night ride with a group of 20-35 people so not massively fast and not hugeley technical, its a steady pace generally with 1500-2000 ft of elevation over 12-14 miles.
Ride no 2 is at the weekend and I try to make it a bigger tougher ride of 20+ miles and 3000+ ft of elevation gain, again its not fast or super technical bit a steady away pace.
I can pretty much ride for 4hrs + at a steady pace but struggle when I have a technical section on a climb that requires an injection of pace to over come it, well the first time is ok but if another section appears in a short distance I'm buggered from the first squirt and go to go over the first section!
Should I be doing interval training or something to allow me to recover better following my initial energy expenditure?
Thanks
Colin
Posted : 18/10/2016 1:34 pm
To be brutally honest, the problem isn't lack of intervals, its lack of riding.
2 days a week isn't enough to improve once beyond the level of a raw beginner.
The only tip I can offer is to find an extra day or two to ride and get your volume up to 6hrs a week (pedalling time, faffing on group mtb rides doesn't count)
Posted : 18/10/2016 1:45 pm
My understanding was that if I was plodding along then essentially ‘sprint’ I am engaging my anaerobic system with all it’s lactic acid by products and associated issues then go back to plodding along where I recover and redress the chemical balance during my next aerobic phase.
It seems to me that my anerobic recovery is not up to the job , is it not correct that I need to practice the anerobic element and the associated recovery?
Posted : 18/10/2016 2:16 pm
I've had it then.
Posted : 18/10/2016 2:17 pm
If you want to ride faster, you need to... err... ride faster.
Glibness aside, 'faster' can either mean ride at the same speed more easily, or riding a higher speed for the same effort.
Either way, if all of your riding is at a 'steady pace', then I doubt you're stressing your body enough to get a decent training response, so I don't think you'll see much more improvement if you've been doing this for a while.
Some things to consider:
- Throwing some interval training into the mix would certainly help, but ideally this should be in addition to your existing riding, perhaps twice a week on a turbo at home. They don't need to take more than 45mins each.
- When on your longer rides on your own, crank it up for the last 20mins, and ride as hard as you can sustain (ie not sprinting).
- Try shorter rides, but do some long intervals, say 20mins focused effort, 20mins off, done three times.
Posted : 18/10/2016 2:59 pm
