Tough lightish 29r ...
[Closed] Tough lightish 29r wheelset.................ideas?
 ton
whats a good strong lightish 29r wheel combo...........
to carry 20stone.
Posted : 28/02/2011 9:39 pm
Hope Pro IIs on Halo Freedom Discs, 32 spokes, 15st, no issues - but I don't know what 'air' is.
Posted : 28/02/2011 9:44 pm
16st on Hope Pro 2's with Flow rims.
Posted : 28/02/2011 9:46 pm
 ton
who did the build please fella's?
Posted : 28/02/2011 9:47 pm
There is an American Classic 29er wheelset now - if it's as good as the 26er one then it'll be worth a look.
LBS in Rhondda in my case - guess that doesn't help you much!
Posted : 28/02/2011 9:51 pm
Freeborn Horsham Sussex
Posted : 28/02/2011 9:53 pm
Ton,I buy my wheels from Just Riding Along,in Oughtibridge near Sheffield.I reckon if you got them to build these http://www.justridingalong.com//shop.php?product=7262 with Flow rims and a heavyweight front hub,you'd have a cracking set of wheels at about 1650 grams.
Ian
Posted : 28/02/2011 10:05 pm
Halo or Stans Flow rims, 36 spokes if you can get them. Hubs - as much as you can afford or as DH / burly as you want.
Posted : 28/02/2011 10:08 pm
 ton
found em now.
billy's has loads.
Posted : 28/02/2011 10:15 pm
I've had Salsa Semi's built up with Hope Pro 2 hubs. Great rims which come with welded seams and pretty light too at 500 grams. And look great and classy in black. http://salsacycles.com/components/semi_29er_disc/
Flows on Pro2 with DT comps. Wide enough for nice big tyres, tough, light.
Built by me 8)
Gordos are nice too but a bit heftier.
Posted : 28/02/2011 10:22 pm
bedmaker, fancy building me some SS wheels ?
Posted : 28/02/2011 10:28 pm
Stan rims on I9 hubs. The straight pull spokes mean you can build em with mor tension so making em stronger.... apparantly!
Posted : 28/02/2011 10:30 pm
And me!
How much for decent 29er rims and hope pro 2 hubs for a S/S project?
Posted : 28/02/2011 10:31 pm
 Moda
Posted : 28/02/2011 10:32 pm
 ton
billy's bikes have loads of 29r rims
and loads of good quality tougher type hubs.
Posted : 28/02/2011 10:33 pm
Edge carbon rims? Strong but light. Not cheap mind.
Posted : 28/02/2011 10:34 pm
I built Flows (32H) on Pro 2s and they are pretty stiff for my 14st frame but I would deffo go 36H for a big strapping lad like you Ton ๐Ÿ˜‰
The limiting factor on spoke tension is the Stans rim itself, you are supposed to build them to a max of 100kg tension on the spokes, but I found I needed a little extra to get them the way I wanted.
Posted : 28/02/2011 10:43 pm
I've got a pair of Bontrager Rhythm 29er wheels that are tubeless ready, pitched as all mountain wheels not XC. They are in good nick and I'm open to offers :mrgreen:
Posted : 02/03/2011 12:24 am
I'm running mustangs on Pro2 with no issues, 32 hole as well, built with crap spokes
they even survived a crash that wrote off a swift
Posted : 02/03/2011 2:01 pm
Run a Hope singlespeed hub so you get a dishless rear wheel. You can still use use 7 cogs from a 9sp cassette on the SS hub. Makes for a very stiff wheel build.
Posted : 02/03/2011 2:14 pm
I had a set of XT hubs built onto Flows rims, 36h rear, 32h front. Seem like a nice set so far and certainly seem strong.
Also still have a 36h new/unused Flow rim in black in the garage which was just being left for the future but i could be tempted to part with it?
Posted : 02/03/2011 2:53 pm
