Torque wrench recom...
[Closed] Torque wrench recommendations
[#6432796]
I'm thinking of buying a torque wrench so what's currently good but not too expensive?
Budget, including a set of basic bits, would ideally be <= £80. I normally buy Park tools but not sure if they are a bit overkill for a torque wrench?
I'm sure this has been asked before but wanted up-to-date recommendations.
Posted : 23/08/2014 12:01 am
*BUMP* Any reviews or recommendations?
Posted : 23/08/2014 8:07 am
I got one for halfords for working on the bike.
3/8" Square drive is reversible and range is 5nm - 100+ nm I think, has a good range never the less.
@bren2709 cheers I'll look on Halfords website I'd assumed they'd start at too high a NM value as they are mostly car stuff 🙂
Posted : 23/08/2014 8:08 am
Norbar SLO - Great bits of kit that we use in the shop all the time.
Posted : 23/08/2014 8:11 am
I used to favour the click in the handle type but the last few years, I've been using beam deflection type. Much quicker and easier to live with I think.
Posted : 23/08/2014 8:13 am
Go for stahlville it's some of the best on the market
Posted : 23/08/2014 8:14 am
I'm old-fashioned and rarely use them, but I've got bending beam types - the click-over type need to be calibrated (and can be way out especially on cheap ones) and if there's one thing guaranteed to break a delicate component it's a wrongly calibrated torque wrench.
Posted : 23/08/2014 8:22 am
This.
Not cheap but excellent quality and very accurate bits of kit.
Posted : 23/08/2014 8:25 am
The beam deflection look the best value and most accurate (im after one too) ... which beam one??
Posted : 23/08/2014 8:43 am
Mine are Park ones...
Posted : 23/08/2014 8:44 am
I've got both of the park ones which are fine.
Posted : 23/08/2014 8:46 am
I got a Giant one which seems nicely made and feels accurate (for now!) I guess I should make a calibration rig at some point - a weight on a lever isn't exactly rocket science. I also have a 4Nm torque key so they can be checked against each other. I was going to get a bending arm type but I'd have needed both Park ones to cover the range of torques on my bike.
Posted : 23/08/2014 8:47 am
"I got one for halfords for working on the bike.
3/8" Square drive is reversible and range is 5nm - 100+ nm I think, has a good range never the less."
Got many left hand bolts ? Its not a socket wrench , it should not be used for undoing bolts.
1-25nm look at wera .
Mines are all teng but if i was buying again if go for the wera for the baby one as my teng is 5-25nm
A huge range on a torque wrench is not desirable . I wouldnt trust a 5-100nm more than my hand.
Posted : 23/08/2014 9:24 am
I've got one of these, £32 from toolstation, Laser brand,( http://www.lasertools.co.uk/default.aspx ) comes with all the calibration documents etc, works a treat for bike bolts...
http://www.toolstation.com/shop/Automotive/Automotive+Wrenches/Torque+Wrench+38/d60/sd3332/p22733
only goes up to 25 IIRC
Posted : 23/08/2014 10:45 am
Trail_rat - do you own a Commencal Supreme V3?
No I didn't think so with your comment posted, Smart Arse!
5 - 60nm range is that acceptable?
Posted : 23/08/2014 11:50 am
Some other really useful tools..
[URL= http://i153.photobucket.com/albums/s202/VST502L/Hazard-Fraught.jp g" target="_blank">http://i153.photobucket.com/albums/s202/VST502L/Hazard-Fraught.jp g"/> [/IMG][/URL]
[URL= http://i153.photobucket.com/albums/s202/VST502L/HF2.jp g" target="_blank">http://i153.photobucket.com/albums/s202/VST502L/HF2.jp g"/> [/IMG][/URL]
[URL= http://i153.photobucket.com/albums/s202/VST502L/HF3.jp g" target="_blank">http://i153.photobucket.com/albums/s202/VST502L/HF3.jp g"/> [/IMG][/URL]
[URL= http://i153.photobucket.com/albums/s202/VST502L/HF4.jp g" target="_blank">http://i153.photobucket.com/albums/s202/VST502L/HF4.jp g"/> [/IMG][/URL]
Posted : 23/08/2014 11:22 pm
Cloudnine, I'm actually crying with laughter. Awesome.
Posted : 23/08/2014 11:32 pm
brilliant looks just like a Toolmart flyer
Posted : 24/08/2014 12:20 am
